Locx ?
Old Dec 15, 2007 | 08:08 PM
n1sm0r's Avatar
n1sm0r
Radio 12v
yellow
radio harness
Radio Ground (chassis)
Radio Ignition lt. green + radio harness
Radio Illumination red/blue + radio harness
Factory Amp Turn-on green/yellow + radio harness
Power Antenna green/white + radio harness
LF Speaker +/- blue/red - black/white +,- radio harness
RF Speaker +/- yellow/red - red/white +,- radio harness
LR Speaker +/- lt. green/red - black/yellow +,- radio harness
RR Speaker +/- blue/orange - black/pink +,- radio harness
that might help.
Old Dec 15, 2007 | 10:34 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
you are getting sound so check the converter. There are pots inside to adjust the gains. Turn the pots until you get some sound... really there is a more exact way to do this but I don't car to explain test tones or the use of dmm.
But, Check the pots. You will need a little screw driver to adjust them.
If the converter for whatever reason does not have the puts, make sure the amp is adjusted (again check the gain pot).
Old Dec 15, 2007 | 10:47 PM
b-ron's Avatar
b-ron
thanks for all the help guys everything sounds good now.
Old Dec 16, 2007 | 06:57 AM
doug's Avatar
doug
Originally Posted by n1sm0r
nothing personal, it's referring to the guy who said connect it to a constant power source, not you
oh yeah.. no prob ..
