Locx ?
Old Dec 15, 2007 | 11:18 AM
b-ron's Avatar
b-ron
Default Locx ?
im trying to put in an amp with stock deck so i got a high low converter, i spliced the wires into the rear speaker wires and hooked up the rca cable and the amp wont turn on what am i missing. i need help
Old Dec 15, 2007 | 12:18 PM
cbr900son's Avatar
cbr900son
HMM more info would help but make sure u have remote on wire, power wire, and ground hooked up right. Also check fuses.
Old Dec 15, 2007 | 12:55 PM
b-ron's Avatar
b-ron
how do i hook up the remot wire i asked the guy if i needed the REM wire and he said no
Old Dec 15, 2007 | 01:06 PM
Lsmith9523's Avatar
Lsmith9523
Yes,,,sound like the remote wire is missing. You will need that wire connected for everything to power up.
Old Dec 15, 2007 | 01:16 PM
michaeljr6's Avatar
michaeljr6
some LOC has a remote wire output....but some don't. just grab a 12v source (cig lighter) and tap it from there and BAM! remote wire.
Old Dec 15, 2007 | 01:18 PM
b-ron's Avatar
b-ron
wow that sounds easy thanks
Old Dec 15, 2007 | 01:54 PM
doug's Avatar
doug
that would mean your amp's turn on everytime you turn the car on.. not when you turn the radio on
Old Dec 15, 2007 | 02:01 PM
b-ron's Avatar
b-ron
the amp turns on but now my sub is not working i have RF p3
Old Dec 15, 2007 | 02:15 PM
b-ron's Avatar
b-ron
now the sub is morking but hardly any bass comes out
Old Dec 15, 2007 | 02:16 PM
michaeljr6's Avatar
michaeljr6
what kind of LOC do you have?
if you have soundgate i can help you....
Old Dec 15, 2007 | 02:20 PM
michaeljr6's Avatar
michaeljr6
actually the cig lighter socket turns on when you put it on ACC so you can still listen to the radio with subs...but it's not recommended as it would drain the battery. if you got a high amp amplifier it's better to turn on the engine.
Old Dec 15, 2007 | 02:41 PM
b-ron's Avatar
b-ron
i have a soundgate
Old Dec 15, 2007 | 02:45 PM
doug's Avatar
doug
OMG thats exactly what i said.. and no.. your amp should always come on with your radio.. not your ignition
Old Dec 15, 2007 | 02:46 PM
doug's Avatar
doug
i have a soundgate
check the wiring.. you might have the speaker wires from the amp to the sub wrong
Old Dec 15, 2007 | 02:51 PM
b-ron's Avatar
b-ron
thats the first thing i checked lol
Old Dec 15, 2007 | 03:08 PM
michaeljr6's Avatar
michaeljr6
alright for the soundgate...open up the cover and there should be plug thing that either set it for the sub setting or the mid speaker setting. make sure the plug is in the sub setting. this will fix your problem 100% and you'll be happy.
Old Dec 15, 2007 | 03:13 PM
michaeljr6's Avatar
michaeljr6
either one still works lol
Old Dec 15, 2007 | 07:05 PM
n1sm0r's Avatar
n1sm0r
Get your year's FSM. Look in the audio section, and tap the remote power. Now the amp will only turn on when your stereo is on.
Nobody here knows what they're talking about.
Old Dec 15, 2007 | 07:35 PM
doug's Avatar
doug
excuse me?
Old Dec 15, 2007 | 07:37 PM
n1sm0r's Avatar
n1sm0r
excuse me?
nothing personal, it's referring to the guy who said connect it to a constant power source, not you
