what subs are you runnin?
Old Dec 23, 2007 | 09:54 AM
2boosted4u's Avatar
2boosted4u
Default what subs are you runnin?
what kind of subs are you guys using and what kind of enclosures do you use??
Old Dec 23, 2007 | 09:56 AM
kacz07's Avatar
kacz07
use the search button bro
Old Dec 23, 2007 | 09:57 AM
kacz07's Avatar
kacz07
https://my350z.com/forum/search.php?searchid=5001201
Old Dec 23, 2007 | 10:00 AM
soleil's Avatar
soleil
NolaZcc
its xmas and i'm gonna be nice
2 jl audio 10w3 v2
zenclosure box
Old Dec 23, 2007 | 10:09 AM
2boosted4u's Avatar
2boosted4u
so i saw in the 100 most asked questions about the 10" sub but do you need a amp for it or is there a stock amp back there? has n e one use this space with sub that needs a closed box?
Old Dec 23, 2007 | 10:10 AM
Try&keepup's Avatar
Try&keepup
2 12 inch eclipse titanium DVCs
Old Dec 23, 2007 | 10:16 AM
soleil's Avatar
soleil
NolaZcc
this question has been asked a bunch...my advice is to search now
Old Dec 23, 2007 | 01:31 PM
2boosted4u's Avatar
2boosted4u
is dyno mating the best way to try to seal the box or would fiberglass be better....lemme guess "use the search button"
Old Dec 23, 2007 | 01:36 PM
soleil's Avatar
soleil
NolaZcc
when i first joined this forum, i spent weeks in this place:
https://my350z.com/forum/forumdisplay.php?f=52
Old Dec 23, 2007 | 02:38 PM
crawfeesh's Avatar
crawfeesh
12" SI Mag - it's not installed yet, but thinking about putting it in a FG box.
Old Dec 23, 2007 | 04:15 PM
Eric the Ricer's Avatar
Eric the Ricer
Single 10' Type R
Old Dec 23, 2007 | 04:40 PM
SuperBlack350z's Avatar
SuperBlack350z
JL w7
Zenclosure
Old Dec 23, 2007 | 05:27 PM
n1sm0r's Avatar
n1sm0r
$35 wallmart special.
Lightning Audio 10'' sub, w/ Lightning Audio amp
The sub is in the stock sub location, and the amp is underneath the glovebox.
Super cheap setup hooked up to my stock non-bose headunit.
I love it.
Old Dec 23, 2007 | 06:29 PM
Fairly Z's Avatar
Fairly Z
Three JL 8W3V3s, Rockford Fosgate 500-1bd (500 Watts RMS @ 1 Ohm)
Old Dec 23, 2007 | 07:28 PM
Z1truth's Avatar
Z1truth
FI.............nough said!
Theres some EXCURSION room with those surround rubbers!!!LOL!
Old Dec 24, 2007 | 12:45 AM
2boosted4u's Avatar
2boosted4u
when you install the sub in the stock location does it loose its lows? are there alot of rattles?? i want to use stock location
Old Dec 24, 2007 | 01:01 AM
SuperBlack350z
that's not the best place for a sub.
Old Dec 24, 2007 | 04:48 AM
StreetOC192's Avatar
StreetOC192
I have a single 10" Diamond Audio in a XtremeKustoms under strut box.
The factory location is not a good place for a drop-in sub. The only way I personally would recommend a sub in the stock location is in the Wicked CAS glove box enclosure. You can google it to see it.
"Dyno mating" (aka dynamat ) is not a sealing product and should not be relied upon to make an enclosure air tight. The best product to use to seal an enclosure made of wood is to use caulking (silicon sealant), or liquid nails. Make sure this is DRY before installing the subwoofer. When silicon sealant dries it lets off gases that can eat away at some foam surrounds.
To make an odd shaped cavity air tight, the best product to use would be fiberglass mat and resin.
Old Dec 24, 2007 | 11:13 AM
2boosted4u's Avatar
2boosted4u
right on! ill look in to the box under the strut then thanks for the help
Old Dec 24, 2007 | 12:45 PM
slapthemonkey's Avatar
slapthemonkey
What MECP certification course did you take? I'd rather not have an installer from there work on my car.
