potential problem with kicker 6 1/2"s
Old Dec 25, 2007 | 08:39 PM
FALLEN1z's Avatar
FALLEN1z
Default potential problem with kicker 6 1/2"s
hey guys, for christmas i got some kicker 6 1/2" speakers and i installedthem with no problems atall. thefront ones are mounted exactly where the old ones were in the doors but nowfor some odd reason when you roll down the passenger window it rolls down all the way except for about an inch before it sounds like it's hitting something and stops. because it's factory sizespeaker mounted in the factory location i wouldnt think there would be a problem. the driver's side works no problem.
any ideas what the issue could be ? when i re-installedthe door panels everything went fine and im clueless
Old Dec 25, 2007 | 08:44 PM
kspec's Avatar
kspec
id take off the door panel and just double check.. even tho it sounds like a pain in the butt! sry dude.
Old Dec 28, 2007 | 01:30 AM
SChetal's Avatar
SChetal
Dude, you need a 1" spacer for front speakers....
The speaker's magnet is what is hitting the window
Old Dec 28, 2007 | 04:23 AM
StreetOC192's Avatar
StreetOC192
+1, you have a couple options here:
1) use the OE speaker as your spacer. There might be a DIY on how to do this, but the short version is to remove the speaker from the plastic housing, mount the OE plastic housing to the door, then mount your new speaker to the plastic housing.
2) use the OE plastic housing as a template on some 3/4" MDF and use that as your spacer.
3) Purchase premade spacers. They are cheap and if you aren't handy and/or don't have the tools to make your own, they are a viable option.
http://www.partsexpress.com/pe/pshow...TOKEN=99118653
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
