Audio Installation Help
Old Dec 26, 2007 | 02:25 PM
El Guy's Avatar
El Guy
Default Audio Installation Help
I have a 05 350Z, Well finally cant take it anymore need to get rid od the back ground noise, I think its bad rca cables and the grounding. I really just want to rewire the hole car, just looks like the shop put the cheapest of cheapest wire they could find. Well i have a pioneer indash Avic-N3 with 2 Hifonics amps 2-Channel for subs & 4 Channles for mids with a Fosgate Capasitor, The Highs front are MB Quarts components and the rear mids are Mb Quarts 6.5
and running 2 10 Punch subs. Well what is the best solution, i really dont want to take to shop again and waste money on a bad job.
What wire should i use for the installation?
Ground, RCA, Speaker wire
Old Dec 26, 2007 | 03:43 PM
slapthemonkey's Avatar
slapthemonkey
What type of background noise are you referring to?
A hiss, a whine...be a little more specific.
Old Dec 26, 2007 | 05:11 PM
SloScooter's Avatar
SloScooter
IF you are getting a hiss or a whistle while accelerating (engine noise) the audio shop probably ran your power wires right next to your RCA's when they ran them back to your amps. I usually run them on opposite sides of the car to avoid this. I am only a recreational installer (DIY) but that is what I would look at first. There are alot of knowledgeable guys on here that may know what it is right off the bat with a little more explanation. Hope I was some help.
Old Dec 26, 2007 | 06:15 PM
El Guy's Avatar
El Guy
I get a hiss when accelerating and when at idle.
Old Dec 26, 2007 | 06:16 PM
El Guy's Avatar
El Guy
Well also i get to radio frequenzy, I think its a bad installation. They are telling me at the shop that the RCA plugs on the AVIC might be bad, but think its the cheap wires they used and the bad ground.
Old Dec 26, 2007 | 06:22 PM
John Bronze's Avatar
John Bronze
also make sure the ground is on the bare metal of the car.
Old Dec 26, 2007 | 07:27 PM
sirfatty's Avatar
sirfatty
where are u going to ground im in the same boat
Old Dec 27, 2007 | 05:57 AM
slapthemonkey
A hiss like radio static, or like a rising and falling whine as you accelerate?
And off what source...CD, radio, iPod?
Old Feb 23, 2008 | 12:35 PM
El Guy's Avatar
El Guy
Rising and falling, on all sources.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
