Usa Spec Pa11nis
Old Jan 10, 2008 | 03:40 PM
AugustXII's Avatar
AugustXII
Default Usa Spec Pa11nis
I recently purchase the USA SPEC PA11NIS and I wonder if anyone out there with it with the 5th gen ipod and does it work with each other? Thanks
Old Jan 10, 2008 | 07:18 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Yep.
I normally run a 3rd gen 15GB, but I just took my 80GB Classic (which I think is considered 6th gen) to my car and it worked fine. Actually it worked better than the 3rd gen.
Old Jan 10, 2008 | 10:11 PM
AugustXII's Avatar
AugustXII
cool, another question, when i plug the ipod into the comp, it just says connected and i can't really play anything on it or control it. does the same thing happen when you plug it in the car? or will you have full control over the ipod?
Old Jan 11, 2008 | 02:49 AM
TreeFiddyZee
Do WHAAAAT!?
There are dip switches on the back that you can set to change the playback method. PM me your email and I'll send the PDF instructions. You'll have to modify your playlist naming slightly also. I assume you have the Bose system with 6 disc in-dash CD changer?
Old Jan 11, 2008 | 04:40 AM
TreeFiddyZee
Do WHAAAAT!?
Found a link to the manual.
http://www.discountcarstereo.com/pdf/pa11-nis.pdf
Let me know if you need some more info.
Old Jan 11, 2008 | 12:02 PM
AugustXII's Avatar
AugustXII
no i have the 07 base model, so it's non-bose, that wont' effect anything though right?
Old Jan 11, 2008 | 12:55 PM
TreeFiddyZee
Do WHAAAAT!?
I'm not sure. Turn on your radio and hit the CD button twice if the iPod isn't plugged in, it should come up onscreen saying, "CD eject". If this doesn't do anything, try hitting the Radio button twice. Once of these should kick the iPod on. I'll do a little more digging to make sure.
Old Jan 11, 2008 | 02:35 PM
AugustXII's Avatar
AugustXII
oh, i ordered pa11nis already but it hasn't come yet, so i'm just making sure everything works before i open it and my car.
Old Jan 11, 2008 | 03:45 PM
TreeFiddyZee
Do WHAAAAT!?
From everything I've read, it should work. PM me when you get it if you have any questions. I've been using mine for quite awhile.
Old Jan 11, 2008 | 06:30 PM
AugustXII's Avatar
AugustXII
will do, thanks man!
Old Feb 1, 2008 | 09:22 PM
davidpham's Avatar
davidpham
I ordered the PA11-NIS for my 2008 350Z Non-Bose Single CD HU.
Apparently the guys at Mobile One couldn't find access to the "CD Changer / AUX" option on the HU.
Any ideas or thoughts?
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
