A little help with box design please
I am going to build a ported box for two 10W6s for the hatch of my Z. I have approximately 9-12 inches in height, 22 inches in width, 26 inches in depth to play with. Would like to have one slotted port. The subs take .75 each. I'm using the spare tire well as the bottom of the box.
I'm mathematically challenged, can someone calculate this for me?
www.reaudio.com has a box calculator you can use to calc the volume, port length, tuning frequency, etc. Just click on the link on the bottom left of the page. I used it to help build my ported box. I have yet to test out the box.
My personal opinion is that if real SQ is what you want, you won't go ported. Sealed is the way to go for a true SQ sub stage.
BUT
according to JL Audio's website:
http://mobile.jlaudio.com/products_s...hp?series_id=6
Tune to 37.89Hz
BUT
Tune to 37.89Hz
Originally Posted by dtak59
a 3.5" port width is too wide. The wider the port width, the higher the tuning frequency will be (or the longer your port will need to be).
Is this a slot port or tube port? If slot port, what is the other dimension to this? If it is a tube port, then dtak59 is correct, although 20+" is pretty long.
Also, the JL site says for a ported enclosure, the recommended volume is 0.75 cu ft, you are making your enclosure over double that?
Originally Posted by StreetOC192
perrogrande007,
Slot port. I'm using two 10W6s, so I'm doubling the enclosure space. I used that program and came up with those dimensions? Suggestions?
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
350Z Project X
Suspension
10-10-2015 09:23 AM
