Mid bass install
Old Jan 16, 2008 | 04:57 AM
ill350's Avatar
ill350
Default Mid bass install
Hey guys need a little help. I am not the most savy when it comes to stereo install / equiptment. I have had a set of Infinity perfect components, just recently both the woofers blew. So I am thinking of replacing the woofers with a set of MB QUART QSC 164 mid bass speakers.
- These pretty decent speakers?
- I am keeping the Infinity tweeters, should I keep the Infinity crossover as well or swap in the one that come with the MB QUART's.
Old Jan 16, 2008 | 05:06 AM
doug's Avatar
doug
i don't like MB Quart .. they sound too muddy.. i would go with Diamond Audio Hex Series instead
Old Jan 16, 2008 | 05:10 AM
StreetOC192's Avatar
StreetOC192
The thing with components sets is that they are designed as a complete set. The crossover points/slopes/topology is designed for the specific drivers in that set. The tweeters and woofers are matched to each other and compliment each other. I recommend highly against just dropping in a different woofer or tweeter without a good bit of research first. Ideally you should find out the parameters/specs of the infinity woofer and find a driver with the same specs. If you pick a woofer with completely different specs it will most likely not sound good.
Old Jan 16, 2008 | 05:17 AM
StreetOC192
^^^ that said here are the specs for the Perfect 6.1 woofer:
Thiele and Small Parameters
Woofer
Revc: 3.45
Levc: 0.37
Sd: 0.0113
BL: 6.37
Vas: 11.43
Cms: 630.36
Mms: 18.94
Mmd: 18.25
Fs: 46.05
Qms: 3.44
Qes: 0.465
Qts: 0.41
Top-Plate Thickness: 9/32" (7.115mm)
Voice-Coil Length: 9/16" (14mm)
Voice-Coil Diameter: 1-1/2" (38.1mm)
Xmax: 1/8" (3.44mm)
Mounting Depth: 2-3/4" (70mm)
Cut-Out Diameter: 5-1/16" (129mm)
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
