AVIC-D3 Install Questions
Old Jan 19, 2008 | 03:51 PM
vAnt's Avatar
vAnt
Default AVIC-D3 Install Questions
After reading many threads about the AVIC-D3, I just have a couple questions that I couldn't find answers to... (2004 350z Touring Vert)
1. If I do get the bluetooth add-on, where can I put it?
2. Is drilling required?
3. Is soldering required?
4. Where are some places you put the ipod cable?
5. Where are some places you put the nav receiver (Trying to avoid dash and I don't have that big strug bar in the back)?
Thanks!
Old Jan 20, 2008 | 05:15 AM
Eric the Ricer's Avatar
Eric the Ricer
avic411.com
and also the search button
Old Jan 20, 2008 | 08:58 AM
gohandbz88's Avatar
gohandbz88
1. I placed the bluetooth box in underneath the white box inside the center console.
2. no
3. no
4. I placed mine in the cubby hole on top of the HU.
5. Inside center console using that magnet that came with the HU and have a perfect reception.
Gl with your install
Old Jan 20, 2008 | 05:02 PM
vAnt's Avatar
vAnt
Originally Posted by Eric the Ricer
avic411.com
Why do you even bother replying if you can't contribute anything? Seriously, you are useless in the FS section, and your useless here. Welcome to my ignore list.
Old Jan 20, 2008 | 05:03 PM
vAnt's Avatar
vAnt
2. no
3. no
Thank you so much! I'll probably use your locations. Anyone else?
Old Jan 20, 2008 | 06:00 PM
350ZPK's Avatar
350ZPK
thats the my350z bunch for you
Old Jan 20, 2008 | 06:06 PM
SuperBlack350z's Avatar
SuperBlack350z
if you know what you are doing, then i would solder. You don't have to but once you see how many wires will be behind the console and how cramped things will be, you'll understand why i suggest this. I soldered everything before i installed..everything is neat and the wires aren't coming apart. I also used heat shrink wrap around the soldered part. Good luck.
Old Jan 20, 2008 | 06:08 PM
Pokémon's Avatar
Pokémon
Thanks!
1. Beneath the AC
4. Drilled a small hole through the cubby.
5. Top of the dash board.
Old Jan 20, 2008 | 07:43 PM
peaches05's Avatar
peaches05
1. i put my underneath the little white box too
2.no
3.no
4. i ran the cable into the center console behind the ebrake, but i already had it apart to wire speakers, if your just putting in the head unit i would just run it into your cubby hole above the radio
5. i ran mine up through the top of the dash right next to the windshield, works good and you wont spot it unless your looking for it
Old Jan 20, 2008 | 08:01 PM
vAnt's Avatar
vAnt
I'd love to but my soldering experience is very limited. I also am interested in a clean uninstall should the car need to be parted with Any pics of your install? I'd love to see it!
Workshop12
Mar 23, 2020 01:45 PM
TrackFiddy
Sep 24, 2015 11:40 PM
Suffolk350z
Sep 13, 2015 02:43 PM
