Would two 10" W6's be overkill?
Old Jan 23, 2008 | 07:26 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
I think the W6's work best in singles or 3 of them(which would be hard to fit)
Old Jan 23, 2008 | 07:27 PM
ARMSTRONGARMS
Can you have to much bass? they make adjustments for that, id just soon know i have it then not.
Old Jan 23, 2008 | 07:39 PM
doug's Avatar
doug
Originally Posted by zdero
I guess I'll probably just stick with one for now. I have not bought the w6 already, but the FI Q sounds like it might be too much bass for me when I have read reviews about it.
so you adjust the cross over and turn it down
Old Jan 23, 2008 | 07:40 PM
doug's Avatar
doug
if i was running a w6 i would take that DE and put it in my mouth.. then have her pull the trigger
Old Jan 24, 2008 | 05:06 AM
C Dubs's Avatar
C Dubs
My opinion is two.....If you go with one you may over-adjust to meet your listening preference. If you go with two you can keep it tight (30-40hz) and still have the volume. Just my experience.......
Old Jan 24, 2008 | 05:31 AM
zdero's Avatar
zdero
Do you think a 500/1 amp would be sufficient for two? Since I would have them adjusted low, I would imagine that would be enough power. Then if I still wasn't satisfied with the bass, all I would have to do would be replace the amp. Does that sound like a reasonable compromise to everyone, or would that just not be enough power for those subs?
Old Jan 24, 2008 | 05:35 AM
doug's Avatar
doug
*sigh*
why are you still thinking about 2 10w6's when we already told you 1 FI Q will sound better?
Old Jan 24, 2008 | 05:53 AM
StreetOC192's Avatar
StreetOC192
Originally Posted by doug
*sigh*
And cost less
Old Jan 24, 2008 | 06:39 AM
350zspl's Avatar
350zspl
if you want JL than do it , power it or them to full rms and the 500-1 will do that for 1 but not both
if you are not gonna take my advise from real world experience and not theory than so be it
your will spend way less money on an custom built FI sub and it will cost less, get louder, get deeper , sound better
the JL will sound good the FI better
Old Jan 24, 2008 | 06:59 AM
VO...'s Avatar
VO...
Administrator
All I can say is I'm glad I listened to you guys when I made my sub selection. I was one of the sheeple caught up in the have to have maintstream components, and would have waisted alot of money....
Old Jan 24, 2008 | 07:16 AM
350zspl's Avatar
350zspl
i have no financial interest in guiding people to certain brands
i have used or installed most all brands
i offer my experience for free take it or leave it
in life you can follow
you can lead
you can walk along side
always try to lead
okay to walk along side
try not to follow
Old Jan 24, 2008 | 07:25 AM
VO...'s Avatar
VO...
Administrator
always try to lead
QFT
Old Jan 24, 2008 | 08:07 AM
clarkemtp's Avatar
clarkemtp
...if you follow, the view never changes.
Old Jan 25, 2008 | 10:50 AM
DVFlyer's Avatar
DVFlyer
Speed of White
There is nothing wrong with following.......
Old Jan 25, 2008 | 12:55 PM
Kwame's Avatar
Kwame
WERD UP!
Old Jan 28, 2008 | 01:04 PM
zdero's Avatar
zdero
Well after all the feedback I guess I should probably listen to you guys and go the fi route. What amp would you recomend to run with it?
Old Jan 28, 2008 | 01:10 PM
SuperBlack350z's Avatar
SuperBlack350z
get jl. Sorry, just wanted to say something different from the rest of the guys.
Get what you want. Not what other recommend.
Old Jan 28, 2008 | 01:11 PM
  #38
DVFlyer's Avatar
DVFlyer
Speed of White
You're going to get even more opinions on amps. There is no "right" answer. IMO, I'd try an Elemental Design amp. Great value and lots of people speak highly of their quality.
But that is one of many you could choose from. I don't know how much power the Fi takes, but IMO, get one with as much power as you can afford (500+ watts).
Old Jan 28, 2008 | 02:08 PM
  #39
StreetOC192
+1 on getting a LOT of different opinions on amps.
If it were me, I would go for a Crossfire VR1000D - 1000 rms into 1ohm. get a dual 2ohm voice coil sub and wire in parallel to 1ohm.
http://www.woofersetc.com/index.cfm?...Product_ID=165
FI SSD 10"= 800rms
FI Q 10"= 1000rms
Old Jan 28, 2008 | 03:24 PM
  #40
sparkplug's Avatar
sparkplug
I have 2 JLW6V2 10" in a ported box. They have plenty of bass for when I need it. And I have about 250rms each. As far as a amp goes I wouldent get a jl unless your getting it for show. You can get double the power or even tripple the power than a jl 500/1 for half the price. For $300.00 you can get a poweracoustik a2400bd. Does close to rated power and great price.
