7001 LCD...is this "normal" for it while playing?? (waves)
Old Jun 18, 2003 | 01:59 PM
KJ-350's Avatar
KJ-350
Default 7001 LCD...is this "normal" for it while playing?? (waves)
got the kenwood dvd and the 7001 finally in and playing and now noticed that there looks like there are small slight "waves" going through the picture!? This is going to be hard to describe b/c when I say "waves" thats they best way to describe it but I dont mean the actual picture is moving when playing. Its like they are in the back ground of the picture! It doesnt effect whats playing at all, its moe or less what I would describe as in the "background". They are not major or something that would really get on ones nerves but I would like to know if I might of got a bad connection somewhere casuing this?
Im assuming that if this is "normal" for the 7001 you guys that have them wil know what Im trying to describe / talking about. But if its not your most likely scratching your head / making an odd face like I am wondering whats up! LOL
Can you guys jump in here with some help, letting me know if you have the same, if somethings wrong etc!? Thanks for any help!!
Old Jun 18, 2003 | 03:46 PM
toykilla's Avatar
toykilla
there are a lot of LCD monitors that do that. Does the waviness increase with higher engine rpms? if so you have som ground noise somewhere in the circuit. does it still wave with the engine off? if so then it isnt ground noise and is the monitor.
Old Jun 20, 2003 | 04:58 AM
Nazar's Avatar
Nazar
This may take a little taking apart the car, Move the dash piece the monitor is mounted on, take a video cable direct from the dvd player and connect it to the input of the 7001. With the car NOT running try and see if it is still there, wiggle the rca cable and see if you notice any waving in the background. Like someone mentioned before it might be just a normal thing that you may have noticed and now you will always know it is there.
Good luck.
Old Jun 20, 2003 | 02:23 PM
KJ-350's Avatar
KJ-350
ok, it does it no matter what. the car running, the car off, teh AC on, the AC off, etc. No matter what is on or off it does this?
Before I get in and take the entire console and dash apart can someone with the 7001 just in please! I know there are a ton of you with this same LCD! Please take a min to post / help out!
Old Jun 20, 2003 | 05:19 PM
Nazar's Avatar
Nazar
Is it something you see when the screen is not powered up.
Old Jun 20, 2003 | 05:51 PM
KJ-350's Avatar
KJ-350
if the screen is not on, no I cant see anything at all. but if the screen is on and the dvd player is not you can still see them sion the screen (black) with the big "NO SIGNAL" in the center.
Old Jun 21, 2003 | 03:35 PM
Nazar's Avatar
Nazar
It is possible something may be wrong with the monitor, Who istalled it, Is it in any way pressed in, or in a tight spot where it may be twisting, These monitors are very sensitive to the touch, so if the case is in any way twisted this will show weird lines when on. Kind of like when the monitor is on and you touch it with your fingers. Make sure the casing is not tightened too much, or check for any twisting in the monitor itself. Check with the installer to make suere there is no problems with the install.
Old Jun 22, 2003 | 12:15 AM
03_ppw350z's Avatar
03_ppw350z
i had this problem with mine the remedy was to unplug the ground witre and ground it directly to the chassis and not to the harness. this solved my problem
Old Jun 22, 2003 | 05:49 PM
KJ-350's Avatar
KJ-350
THANK YOU for chimming in! Cant beleive that so many people have this same screen and wouldnt take a min to say anything at all about theirs! I have mine to the harness right now, wonder if thats the problem as yours was. Might try to redo that tonight and see what happens! Thanks again
Old Jun 22, 2003 | 06:30 PM
rouxeny's Avatar
rouxeny
I have noticed occasional wavy lines, but nothing too big.
I'm sure it has to do with the wiring.
Old Jun 23, 2003 | 06:18 AM
KJ-350's Avatar
KJ-350
well i guess i ended up getting a bunk *** LCD! i changed the ground wire from the harness to the chassis (sanded the area etc. screw and washer) that didnt do anything. so did it again to another spot..same thing! then even changed out the video line...same thing, no difference.
Old Jun 28, 2003 | 10:45 AM
KJ-350's Avatar
KJ-350
NAZAR..tired PM'ing you but your mb has been full.
what / can you do anything about the 7001 I bought from you? I tried everything that would make a difference and nothing worked. I changed the ground 3 times and have tried 2 different video cables as well. The picture still has those white waves when ever its on, it has to be something with the LCD. Can send it back for another one since its having these problems and everyone else I emailed or PM'd that also has the 7001 said they dont have this problem with theirs, that their picture is perfect! My email is kev328ci@bellatlantic.net if thats better than PM's for you. Let me know ok! Thanks...Kev
Old Jul 6, 2003 | 07:59 PM
Nazar's Avatar
Nazar
I Pm'ed you.
I will talk to the rep and see what I can do.
aarrgghh
May 1, 2022 11:04 AM
bcoffee20
Nov 19, 2015 06:39 PM
TrackFiddy
Sep 24, 2015 09:36 AM
3vilbunny
Sep 13, 2015 12:31 PM
PureR3d
Sep 10, 2015 06:23 PM
