Where should I ground my amp which is in the glovebox?
Old Feb 13, 2008 | 03:18 PM
Asian Invasian's Avatar
Asian Invasian
Default Where should I ground my amp which is in the glovebox?
Thread title says it all.
Basically the amp is in my glovebox and I am wondering where I can ground the amp to?
Old Feb 13, 2008 | 03:37 PM
Asian Invasian
ttt
Old Feb 13, 2008 | 03:40 PM
phreaktor's Avatar
phreaktor
Design Engineer
the bolt at the back of the glove box?
Old Feb 13, 2008 | 03:41 PM
StreetOC192's Avatar
StreetOC192
Bumping your own thread after 19 minutes?
You will probably have to drill a hole through the plastic and ground inside the cubby. Or you can route the ground through the back of the cubby into the hatch area and ground it to the child seat anchor bolt.
Old Feb 13, 2008 | 04:09 PM
Asian Invasian
I bumped it because It was getting dark and I wanted to know before it got dark, too late :'(
Thanks for the replys.
Old Feb 13, 2008 | 04:33 PM
StreetOC192
Ahhhh, caught in the middle of the install. OK, I understand now. Hope I didn't sound like too much of a pr!ck.
Old Feb 13, 2008 | 08:31 PM
Asian Invasian
No I would have questioned me if I was you too haha.
Old Feb 13, 2008 | 08:34 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
It doesnt matter? just pick the easiest spot, a ground is a ground.
Old Feb 13, 2008 | 09:25 PM
BabyZiLLa's Avatar
BabyZiLLa
Remind me not to get you to do my install..
I haven't done my install yet so im not familiar with the good locations on the Z. Just make sure you sand it down to bare metal where ever you do.
Old Feb 13, 2008 | 09:33 PM
ARMSTRONGARMS
^lol my system was awesome! I know how to hook up something, i think if you have to ask a how to ground/where to ground then you shouldnt be hooking up this yourself? A ground is a ground? No? it's either grounded or not correct
Old Feb 13, 2008 | 09:42 PM
Sean's Avatar
Sean
The best thing to do in the glove box is to ground it to your gun, that is what all the real men do.
Old Feb 13, 2008 | 09:50 PM
BabyZiLLa's Avatar
BabyZiLLa
So you've never heard of a bad ground? Or ground loop?
How can you say a ground is a ground..
Old Feb 13, 2008 | 10:06 PM
ARMSTRONGARMS
a bad ground isnt a ground now is it?
phreaktor's Avatar
phreaktor
Design Engineer
+1 Hitting the brakes and having the horn beep ftl...
Ahh the good old days of being the "Teenage Neighborhood Installer"
Old Feb 14, 2008 | 06:06 AM
BabyZiLLa's Avatar
BabyZiLLa
Nope. And if you think it is i'd hate to see your installs.
Is installing 3/6 forged pistons building the the block? Its half assing.
Old Feb 14, 2008 | 11:24 AM
PPW_07_Z's Avatar
PPW_07_Z
Hmm, yeah I drilled a hole in the plastic piece in the glove box and routed the wires through it...the ground is attached to some huge bolt on the body that I found by looking around in there with the flashlight :-D Sure hope that was an OK spot :-D With the carpet piece back in place and the amp turned the right way you can't see the wires at all...love it!
Old Feb 14, 2008 | 11:38 AM
doug's Avatar
doug
i grounded my amp to the baby seat latch
Old Feb 14, 2008 | 05:45 PM
smaha's Avatar
smaha
my rule is find the thickest metal, closest to the amp then grind down to bare metal. the shorter the ground lead, the better. if you can get to chassis to ground, that would be the best.
Old May 2, 2008 | 09:29 AM
nyguy4u's Avatar
nyguy4u
sorry to bring up a somewhat old topic, but I don't want to start another thread.
I am in the middle of tapping into my fusebox inside my 04' Z to hardwire my Escort. What's the best grounding spot? I looked everywhere near the pedals, and can't really find a good place.
Any ideas?
Old May 2, 2008 | 09:43 AM
doug's Avatar
doug
Any ideas?
center brackets where the radio is? center console where the shifter is?
get a volt meter.. if you are a DYI'er and you do alot of electronic stuff.. get a volt meter.. it will save you lots of time
