Amp install...help!!!
Old Feb 18, 2008 | 12:13 PM
sleeper832's Avatar
sleeper832
Default Amp install...help!!!
I've been lookin around here for a while trying to find info on getting the power cord for an amp through the fire wall, so if it's listed, i didn't find it....sorry to post again if it's up
So yeah, need to know if there are any areas on the firewall that allow for the cable to run through, or if anyone just drilled? ANY help would be great....
Old Feb 18, 2008 | 12:20 PM
sintaxeror's Avatar
sintaxeror
Next time, check the "how-to" stickies at the top there.. and also the DIY forum sections are a good place to check...
https://my350z.com/forum/showthread....threadid=26618
Old Feb 18, 2008 | 12:22 PM
350zspl's Avatar
350zspl
go thru passenger wheel well
Old Feb 19, 2008 | 12:25 AM
DUBZRO's Avatar
DUBZRO
behind the battery there is a spot, cut the rubber with a razor(carefully) and feed it through, take off the kick panel(passenger side) and u will see the wire. i just did it a few hours ago and it only took 5 mins
Old Feb 19, 2008 | 01:09 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
Yes i concur to the above statements.
Old Feb 19, 2008 | 02:11 AM
Zero+4's Avatar
Zero+4
silicone around the hole too.. unless you want your car to leak
Old Feb 19, 2008 | 02:16 AM
AUtigers350z's Avatar
AUtigers350z
https://my350z.com/forum/showpost.ph...8&postcount=45
There are some pictures of my install. Hope they help out.
Old Feb 19, 2008 | 01:35 PM
sleeper832's Avatar
sleeper832
THANK YOU for all your help and pointing me in the right direction!
The pics all really helped and that install with the xbox looks clean as hell man, nice job!
Thanks again!
more !!! for good measure
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
