Hooking up subs help!!!!
Old Feb 22, 2008 | 08:38 AM
white07z's Avatar
white07z
Default Hooking up subs help!!!!
Well i got 2-12in. kicker comp subs 300watts 4 ohm each each that im trying to hook up to a 300x1 mono amp not sure on ohms also kicker, what would be the best way to hook it up to get the most out of the subs and amp..im also gonna be hooking it up to the factory head unit, i got a converter for this but i need to know where behind the head unit to hook up the wires or where to plug them in! Im looking to get clear good sound but i want it to hit too..
I need some good clear instructions, any advice would help, im gonna be doing the wiring so...precise instrctions a must!!! Thank you!!!
Old Feb 22, 2008 | 09:42 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
Originally Posted by white07z
Well i got 2-12in. kicker comp subs 300watts each that im trying to hook up to a 300x1 mono amp also kicker, what would be the best way to hook it up to get the most out of the subs and amp..im also gonna be hooking it up to the factory head unit, i got a converter for this but i need to know where behind the head unit to hook up the wires or where to plug them in! Im looking to get clear good sound but i want it to hit too..
Are your subs dual voice coil or single voice coil? Also what ohm are the subs and what ohm is the amp rated for? If you can provide that info someone can answer your question and point you in the right direction.
Old Feb 22, 2008 | 09:55 AM
white07z's Avatar
white07z
2 kicker comp subs 300watts each 4 ohms I'm pretty sure they r single voice coilovers...amp is 300x1 mono not sure on rated ohms..with stock head unit using a converter.
Old Feb 22, 2008 | 10:08 AM
bryan@Z1's Avatar
bryan@Z1
You need to make sure what ohm your amp is capable of running because that will determine how your subs need to be hooked up. If you have single 4 ohm subs you'd better hope that amp will run 2 ohm stable otherwise you're gonna want to swap those subs for 8 ohm models.
If the amp is 2 ohm stable it's an easy hook up from amp to sub. If it's not then you really need to exchange those subs for a pair of 8 ohm subs. Also verify FOR SURE that you have single voice coil subs that determines how they are wired as well.
As for hooking up a LOC (line output converter) there is a wiring diagram around on the forum you can look at and get the correct color wires to tap into to hook that up. It doesn't have to be hooked up behind the radio to feed a mono amp it can be hooked up to any speaker in the system.
Old Feb 22, 2008 | 10:18 AM
Ichigo's Avatar
Ichigo
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Old Feb 22, 2008 | 10:34 AM
white07z's Avatar
white07z
ok I got I will find out more bout the rated ohms n the coils.. Thnxs
Old Feb 22, 2008 | 10:39 AM
bryan@Z1's Avatar
bryan@Z1
That's a great one. I was trying to remember what company had that wiring wizard. Good link.
Old Feb 22, 2008 | 11:10 AM
white07z's Avatar
white07z
Well Thanks Alot Guys That Helped Alot!!!!!!hopefully We Can Some Beats For This Weekend
Old Feb 22, 2008 | 01:16 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Have you run power, ground and remote turn on already? And are your subs going in some sort of an enclosure?
Old Feb 23, 2008 | 06:03 AM
white07z's Avatar
white07z
yes they are in a fiberglass enclosure, its in front of the strut bar behind the seats facing forward, at an angle up. I have ran the power, ground and remote already to. I had it hooked up before, but it didnt hit very loud, i think the guy that did it, did it wrong or something. so im gonna do it myself.
roadmax
370Z Roadster
Aug 5, 2021 08:01 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
350z82
Oct 1, 2015 06:25 PM
Tochigi_236
Sep 27, 2015 03:40 PM
