Very clean Radar install
Old Jun 23, 2003 | 08:27 AM
spydr's Avatar
spydr
Default Very clean Radar install
Here is my Valentine 1 installed.
Old Jun 23, 2003 | 08:28 AM
spydr's Avatar
spydr
Anoyher pic
Old Jun 23, 2003 | 08:29 AM
spydr's Avatar
spydr
Lasy one
Old Jun 23, 2003 | 08:35 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Very nice man.
What bracket did you use to mount the V1 ?
I can see you have been busy! (Where'd you pick up the Borla?)
Old Jun 23, 2003 | 09:37 AM
spydr's Avatar
spydr
I got the bracket from Zip products 800-962-9632 I modified a bracket they sell for a C5 Corvette part #X-1190
Old Jun 23, 2003 | 09:52 AM
spydr's Avatar
spydr
Originally posted by dh1111
Very nice man.
I got the Borla from StrictlyZ.com
Old Jun 23, 2003 | 05:49 PM
vics350's Avatar
vics350
Spydr, that looks awesome. Very clean job. I keep staring looking for the wires but you did a great job hiding them. Can't wait to see it in person.
Old Jun 23, 2003 | 07:50 PM
Buub's Avatar
Buub
I assume you opened up the headliner to run the wires with the rv mirror wires? Or did you run it around the edge of the windshield?
Looks nice, I've been putting off doing the same thing with the hidden remote module. I assume you put that guy in too.
Old Jun 23, 2003 | 09:06 PM
MannishBoy's Avatar
MannishBoy
I did basically the same thing with my Escort back in January, and I think some others did it before I did. There is a thread or so floating around with pics.
I went to the fuse panel, instead of splicing up to the rear view mirror wires, so that I wouldn't have to mess with stuff in a tight location or pull part of the headliner down. Just push the wire in with the edge of a credit card where the orange line runs in the pic. Follow the door side of the molding down and into the kick panel fuse panel. No opening of the headliner or roof console needed:
Old Jun 23, 2003 | 09:23 PM
Hammerman's Avatar
Hammerman
Got twisties?
spydr, what modifications did you have to do to get that bracket to fit? Did you re-use the orignal mirror mount screw, or use the one provided in the kit?
I tried both, but had no success...the original mirror mount screw appeared to be too short to reach the threads once the additional thickness of the zip bracket was in the mix, and the screw supplied with the zip bracket didn't seem to thread properly at all.
Color me confused.
Old Jun 24, 2003 | 05:31 AM
spydr's Avatar
spydr
Ther first thing I did was bend the tab that mounts to the mirror so it was straight. I then drilled out the hole that the mounting bolt go through just enough so the bolt will fit without threading it through the bracket. The bolt supplied is too long so you can go to the local hardware and get a shorter one. I just added 3 small
washers and used the lock washer that came with the bolt. Put the lock washer on then put the bolt in the bracket slip the washers on the back side of the bracket. I also put a drop of locktite on the bolt. The bolt fits it just that you have to get the exact angle to thread it. Snug it up until there is no movement of mirror or bracket. I also added a foam disc I made and put double sided tape on it and placed it on the bracket so it would not move when you hit a bump.
Old Jun 24, 2003 | 08:01 PM
jonghj's Avatar
jonghj
Nice job!!!
Old Jul 6, 2003 | 03:05 PM
Taya's Avatar
Taya
Default Dumb question?
This is really a nice job, I wondr, since the mirror has electricity for it, can't we just use that to power the detector?
Old Jul 6, 2003 | 03:38 PM
MannishBoy's Avatar
MannishBoy
Sure, but then you have to splice in up under the the headliner. I though it easier in my case to just run the line down the A pillar to the fuse box.
Old Jul 6, 2003 | 05:36 PM
chromesilverz's Avatar
chromesilverz
Nice job...but isn't your radar a little high?
Where is the rear sensor locatedon the V1?....
Old Jul 6, 2003 | 07:02 PM
zland's Avatar
zland
Sport Z Magazine
Can you install it like this in California, is it legal? Will the cops hassle you? How does it work in this location? What was the cost of this bracket and parts to do this install. Looks great!
Thanks, Jeff
Old Jul 6, 2003 | 08:46 PM
sdpearso's Avatar
sdpearso
Radar detectors are 100% legal everywhere in the US with the exception of Virginia and Washinton D.C. (per www.radartest.com)
Whether the cops will hassle you is another story...but you don't need a radar detector to be hassled.
Old Aug 16, 2003 | 12:03 PM
Zyasooner's Avatar
Zyasooner
A 10/24 x 3/4 inch screw worked well to mount the bracket to support the radar unit. No drilling of mirror mount required. Exact size is a 5 mm with a 1.00 or 1.25 pitch but the onlything I've been able to find is a standard .8 pitch. The 10/24 worked fine though.
Old Nov 26, 2003 | 01:38 PM
shorki's Avatar
shorki
Question which fuse did u use ?
which fuse did u tap into and does the radar only come on when the car is on ?
Old Jan 6, 2004 | 09:05 AM
JimRHIT's Avatar
JimRHIT
bump ... just got my V1 ... and wondering what fuse to tap into so that i only power on when the car is on.
thanks in andvance
jim
