Very clean Radar install
Old Jan 7, 2004 | 03:37 PM
MannishBoy's Avatar
MannishBoy
Accessory.
Old Apr 12, 2004 | 08:30 AM
MarkY's Avatar
MarkY
Has anyone used this mounting method on a roadster? It seems like the mounting would be OK but the hardwiring of it would be different. Obviously I couldn't run the wire via the headliner and I'd hate to have to tap in to the rearview mirror wiring.
I'm thinking of dropping the wire down to the dash and running it to the power socket on the passenger side next to the cosole.
Any other ideas?
Old Apr 12, 2004 | 09:12 AM
Whataguy5431's Avatar
Whataguy5431
Default V1 install Roadster
Had the dealer do mine for me. You can't wire into mirror line, cuts voltage and underpowers V1.
Headliner is removable, clean all the way down to converter at fuse box.
Old Apr 12, 2004 | 10:32 AM
MarkY's Avatar
MarkY
Default Re: V1 install Roadster
I have a roadster. Headliner isn't an option.
Old Apr 12, 2004 | 11:43 AM
Whataguy5431
Default I have Roadster Also
Sorry, maybe I called it the wrong name. The ran the wires under that plastic trim that supports windshield frame, I called it headliner by mistake. I've got an LS/BO roadster.
Old Apr 12, 2004 | 01:03 PM
MarkY's Avatar
MarkY
Thanks for the clarification, that makes more sense. I'll look at doing it that way.
Did you get the zip bracket from http://store.yahoo.com/corvetteforum/19valraddetm.html
Also, which fuse did you use in your roadster?
Old Apr 18, 2004 | 01:35 PM
2NthuZd's Avatar
2NthuZd
Just some FYI
The mirror wires run across the headliner and into the Apillar. Look at the wires on the mirror plug, and you'll quickly find them in the drivers side A-pillar. There you can tap the power and ground, or even better use a bolts right there under the A-pillar for your ground. The power wire you'll want to tap is red and black. This will turn your V-1 on when you turn the key to power on.
I've had it this way on the WRX for a long time now, and no probs ever
Old Apr 20, 2004 | 09:41 PM
DTM323's Avatar
DTM323
awesome setup, any pics from outside the car? Just curious if it looks clean.
nanotech
Oct 2, 2015 05:02 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
