Official Kenwood DDX512 thread
Old Oct 4, 2008 | 03:36 AM
  #61
Ghost_shift's Avatar
Ghost_shift
Originally Posted by chriztian
firmware 1.5.1 is out now...
This is great! It fixes my Bluetooth problemsZ!
Old Nov 11, 2008 | 02:02 PM
  #62
sellin04's Avatar
sellin04
Default Problems...
I'm having troubles installing the new update...I tried burning it onto a couple CDs and it plays a terrible sound. Then I can get it to read on a DVD but never finishes uploading, Kenwood's site says around 5 mins to complete (I've left it in for around a hour one time). Any ideas?
Another question...when my iPod is plugged in the unit says the iPod is disconnected but still plays music just doesn't let me control it, I was hoping the update would fix it. I do have an iPod Touch, does anyone else have a touch that allows it to control it from the iPod screen?
TIA
Old Nov 11, 2008 | 04:05 PM
  #63
Mr MoUnTaInMaN's Avatar
Mr MoUnTaInMaN
TIA
I had a simlar problem and called kenwood a few times they told me to nero to burn the disc did not think it should matter but it did made a new disc and it worked. hope this helps. I also have a ipod touch and have had many problems with if your ipod is jailbroke unjailbreak it when i went to 2.0 the new firmware it worked much better and i can play video from my touch to cool could not do that before.
Old Feb 5, 2009 | 12:04 PM
  #64
sry110's Avatar
sry110
I installed my ddx512 over the summer of 2008 (I think I posted earlier in this thread too), but just last night I had something weird happen. I started the car, and the screen came on, but the sound never came on. When it turned on it was on the iPod channel, then I switched it to Sirius, then to FM, then to CD/DVD and no sound would come out. I even turned it all the way up. My amp was fine (as far as I could tell...the normal power indicator light was on so I figure it was OK). It was cold out but I've run the unit in colder temperatures before without any issue.
So I turned it off and went to the gym and an hour later turned it back on, and it worked. So now it's suspect. Has this happened to anyone else here? If so was it a problem with your HU or your amp? And how did you remedy it? Thanks..
Old Feb 6, 2009 | 06:00 AM
  #65
Mr MoUnTaInMaN
Make sure you have the latest firmware update mine seems to run great since the last update if that does not help then and the problem persist i would take it out and go to kenwood if you have a dealer close by thats what i did they were very helpfull but try the update. hope this helps.
Old Feb 6, 2009 | 08:55 AM
  #66
sry110's Avatar
sry110
Thanks I will try installing the new firmware update. Any idea if it will read it off a usb thumb drive, or do I have to use a CD?
Old Feb 11, 2009 | 12:48 PM
  #67
siruis's Avatar
siruis
Is this compatible with steering wheel controls? If ordered from cruchfield do i need a seperate dash kit?
Old Feb 11, 2009 | 05:23 PM
  #68
Mr MoUnTaInMaN
You must use a CD and if you have any problems try using nero to burn the CD good luck
Old Feb 11, 2009 | 05:25 PM
  #69
Mr MoUnTaInMaN
I dont know if it has any compatiblity wth steer wheel controls sorry
Old Feb 14, 2009 | 05:43 AM
  #70
350z-Helsinki's Avatar
350z-Helsinki
It works with swi-jack by Pac-audio.
Old Feb 23, 2009 | 07:36 AM
  #71
siruis's Avatar
siruis
SO i decided to purchase this one. Will be doing it in a few weeks. Will get the refurbished unit from crutchfield with an extended warranty, the swi-jack for audi controls, the IPOD cable, and the Sirius package for kenwood. The sirius is out of stock so il wait until they have it in and order everything together. I think total will be around $550 and i will install myself with my friend who can easily do this.
Old Feb 23, 2009 | 08:45 AM
  #72
siruis's Avatar
siruis
Also does someone have a install guide for this which may help us!!??
Old Feb 26, 2009 | 02:05 AM
  #73
crZydave's Avatar
crZydave
firmware 2.4.0 is out now...
Old Feb 26, 2009 | 05:48 AM
  #74
Ghost_shift
Can someone post a link to the new firmware update???
Old Feb 26, 2009 | 03:11 PM
  #75
crZydave's Avatar
crZydave
No prob...
http://www.kenwood.com/cs/ce/mm/firmware/2008/eng.html
Old Feb 26, 2009 | 03:28 PM
  #76
Ghost_shift
thank you!!! Now my wma's work awsome!
Old Mar 8, 2009 | 05:16 PM
  #77
celsesser's Avatar
celsesser
Dash Kit question for DDX512 and 350Z, 2005 Roadster. I had an installer at BB (BestBuy) tell me you can install this unit with or without a dash kit. Anyone have any opinions on this? I say order the dash kit but would like advice of people who have this is receiver.
Thanks!
Old Mar 9, 2009 | 10:34 AM
  #78
katdadi's Avatar
katdadi
I have the DDX512 and was wondering, how do you make the background image the you install cover the full screen? I loaded a jpg but it is not full screen. Is there a setting for this?
Old Mar 13, 2009 | 06:04 PM
  #79
MichaelofHearts's Avatar
MichaelofHearts
I just installed the head this morning, I love it but I have the stock nav on my 2003 track. Anyone else have problems with the nav not working?
I got it to work finally but Im worried it might stop soon so if theres a module or anything I need just figured Id ask now.
As for the resolution kenwood says the image should be 480x234 to be "fullscreen" but I havent tried it yet.
Old Mar 16, 2009 | 03:46 AM
  #80
celsesser's Avatar
celsesser
Resize the image to 480x234. It works, I just did it on mine.
