carputer steering wheel interface??
Old Mar 10, 2008 | 09:30 AM
carlos067's Avatar
carlos067
Default carputer steering wheel interface??
guys I need your help, I started thinking about interfacing the switches on the steering wheel (Volume, seek, etc.) with a carputer. Here is what im thinking find the leads for each of the commands then I can figure out how to have the computer deal with it. But I ran into a prob so far:
when you push a different button does the resistance in the circuit change?? I think im reading this correctly. So its not different leads that each button shorts. Any ideas on how I could do this? Or am I reinventing the wheel and someone has already done this?
Old Mar 10, 2008 | 09:57 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Yes - each switch direction changes the resistance in two different leads. The PAC interfaces can read this resistance change and transmit a matching learned IR signal so if your carputer can take an IR input for the radio controls you're golden.
Old Mar 10, 2008 | 10:05 AM
carlos067's Avatar
carlos067
is the PAC interface meant to mimic the remote control of a specific head unit or is it a ir signal you can adjust?
Old Mar 10, 2008 | 10:59 AM
MDK's Avatar
MDK
Couldn't you just plug this straight into a serial port and make a basic driver to read a differential signal?
Old Mar 10, 2008 | 12:34 PM
sintaxeror's Avatar
sintaxeror
No.
You could get a circuit made to interface with your serial port though...
I'm not sure exactly where they are measuring the resistance in that info you posted though...
edit: oh I get it now. You could easily get a circuit made to convert the signals into something you can use.
Old Mar 10, 2008 | 01:52 PM
Project3fiftyZ's Avatar
Project3fiftyZ
I remember back in my Honda carputer days when I lurked on mp3car.com that this guy in MD with a G35 coupe actually took the time to rip his steering wheel apart and do this. I would run some searches on there and I am sure you will find his install....one of the best ones out there.
Old Mar 10, 2008 | 02:18 PM
Mikey-Z's Avatar
Mikey-Z
Get PAC adapter and usbuirt.
Then get girder to recognize the IR signals and kick out corresponding keystrokes.
Old Mar 10, 2008 | 04:06 PM
carlos067's Avatar
carlos067
I've actually been looking up stuff on Girder and it seems like the most likely/easiest answer. However i've also read that somehow the PAC adapter lags after you give it a command. Also thanks for the info project3fiftyZ, im going to look on there and hopefully find something that I could hardwire.
Old Mar 10, 2008 | 05:38 PM
carlos067's Avatar
carlos067
thanks alot project3fiftyZ I found exactly what i need on mp3car.com
http://www.mp3car.com/vbulletin/inpu...tml#post197860
for those interested
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
