Box building question
Old Apr 13, 2008 | 04:54 PM
Shyn's Avatar
Shyn
Default Box building question
Is there a general amount of minimum space from the bottom of the subwoofer's rear vented hole (bottom of sub) and the back wall of the enclosure?
Might sound confusing but for example, the Hertz Mille 2500 states there must be a minimum of 50 mm. Does this vary from sub to sub, or does it even matter with some subs.
My concern is picking a sub that will fit in an enclosure, but might not perform well due to this.
Im hoping the "audio gurus" lurking around in here can help me out.
Old Apr 14, 2008 | 05:45 AM
350zspl's Avatar
350zspl
if you are talking mounting depth
distance from enclsoure floor to bottom of motor leave 1/2"
Old Apr 14, 2008 | 06:20 AM
sintaxeror's Avatar
sintaxeror
That pole vent helps to cool the motor, so just make sure there is enough room for air to flow freely.
Old Apr 14, 2008 | 07:43 AM
Shyn's Avatar
Shyn
350zspl
I think me and you are on the same page, i didnt know that the back wall of the enclosure (opposite to the wall where you mount the sub) is considered the "enclosure floor".
The Hertz Mille 2500, as i stated earlier, required a minimum of just under 2 INCHES! So that got me thinking and second guessing myself.
Thanks for the input guys, if anyone else has any kind of input or knowledge on the issue it would be greatly appreciated
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Tochigi_236
Sep 27, 2015 03:40 PM
