stock subwoofer amp replacement
Old Jul 13, 2008 | 09:24 AM
J rad's Avatar
J rad
Originally Posted by Pete's 03SVT
The godly insrument you need to remove the woofer is a 10mm socket . The amplifier for it is mounted just to the passenger side of the woofer with 2 more 10mm bolts that are visible from the front of the woofer mounting plate. You can reach through the woofer hole and remove the amp once you loosen the 2 bolts that hold it in place. It is a small (roughly 5" x 5" x 3") box with a black cover, has a plug with 7 wires, and has a "Bose" sticker on it.
So would it be safe to run an AM amp off of this one??
Old Jul 14, 2008 | 04:29 AM
Will_Evo's Avatar
Will_Evo
Default here is an Add On
Instead of make my own topic I figure I will just piggy back this one.
2003 Z w/bose
When installing a new system to say a DNX7120, the stock amp to the stock sub automatically gets canceled out through the aftermarket wiring harness or do you have to disconnect the connection at the amp to make sure its off?
Is it possible to replace the stock speaker amp in the back with a aftermarket one..and use the existing wiring for the speakers..I am sure the power and ground would have to be run but what about the actual speaker wire? And how big is the stock speaker amp space in the back? Big enough to fit a small 200 watt amp?
Thanks for the help...
Will_Evo
Old Jul 19, 2008 | 09:52 AM
Nazar's Avatar
Nazar
Just go with an aftermarket amp and an aftermarket Sub replacement.
We make a Glove box enclosure for the 350Z.
Old Jan 21, 2009 | 07:44 AM
SilverSpear's Avatar
SilverSpear
Risen from the dead... but what is the configuration of both the speakers and sub amps in the 350z? (Bose)
10x
Old Jan 21, 2009 | 12:50 PM
SilverSpear
Bump for the Q?
07ZEKE
Aug 23, 2021 09:15 PM
ablaine
Nov 29, 2016 10:13 AM
pr_350z
Oct 1, 2015 05:03 PM
