stock subwoofer amp replacement
Just searched through the whole audio and diy audio sections and coudln't find anything.
03 stock touring z with bose sound system.
Dealer told me that my sub amp is dead and needs to be replaced. I bought my own sub amp and asked them to put it in but they wanted to charge me 150 for it, and thats after they charged me 70 to tell me that the sub amp was dead.
Didn't want to pay that much so i decided to stick it in myself, problem is i don't know where the sub amp is looking for any help, if anyone knows how to access it or even where the hell that thing is that'd be great.
-Thanks
-Thanks
You know where the spare tire is? When you're at the back of the car looking forward, it's under the left side black styrofoam piece. You have to remove the rear plastic, and the side plastic to get the styrofoam out. The amp is secured down with 3x 10mm nuts.
it's secured with one or two of those hook things.
Use a screwdriver to pull the things up and they lift out. Then, just yank on the panel, since the rest is held by the snap-in-hole connector type things.
wait, your replacing the stock Bose amp with an aftermarket amp... Does the stock bose amplifier handle the front and rear speakers as well? What amplifier did you purchase? How many watts and channels?
Methinks you should do a lot more research. I've never worked with a bose setup in our Z's so I dont know, but it sounds way too easy to just replace the stock bose amp with an aftermarket one.
IMO this is going to cost more than you want to spend to fix properly. I would try to get a Bose amp from someone here on the forum thats already removed theirs in favor of a completely new system.
My appologies if you have already considered all of the above, but I would'nt want you to spend the dough and be disapointed with the result.
yup bought a bose amp. sorry if that wasnt clear.
there were two amps for me in my 2003 bose, i think the subwoofer one was adjacent to the woofer itself(a small black box) while the speakers amp was in the back near the spare and it was silver.
if you need a bose sub amp i can sell it to you for cheap.
thanks but i bought the whole set off another member, speakers amps everything. Now im just looking to see how to access the amp, cant seem to get the plastic or the styrofoam off.
Originally Posted by aznriceball2
but how do i get to it??
sorry i was asking how to get to the subwoofer amp. I'm guessing its behind the subwoofer so i tried to dig it all out.
Then i ran into these super bolt/screw things. What kind of godly instrument do i have to use to takes these out, i tried a screwdriver to no avail, and wrenches wont fit because of the way the sides turn up
The godly insrument you need to remove the woofer is a 10mm socket . The amplifier for it is mounted just to the passenger side of the woofer with 2 more 10mm bolts that are visible from the front of the woofer mounting plate. You can reach through the woofer hole and remove the amp once you loosen the 2 bolts that hold it in place. It is a small (roughly 5" x 5" x 3") box with a black cover, has a plug with 7 wires, and has a "Bose" sticker on it.
Thanks for the great info and pics. My sub has started to go in and out lately and I'm gonna post a "wanted" for a sub amp later today. At least I know what I'm in for when I buy a used one to replace my failing sub amp.
Originally Posted by thaeviltwin
Hey i'm new to this form but i was wondering if i could just drop a 12 inch audioban sub where the oem bose sub is would it hit or should i just get a box for it
