Avic Z1 in cubbyhole
Hey all,
Has anyone ever installed a AVIC deck in the cubbyhole of their 350z and keep the door or had to remove it? I have a AVIC Z1 deck I would like to try and install there. I have combed the forum and havent seen it done, though I have seen alot of people people who throw a 7 inch screen there. How flush would the installation look since it is not flat like where the radio is? Also would I have to more than likely build a front out of bondo to make such an install possible?
Agreed. There's only a couple of inches worth of space back there - not the 8 or 9 needed by a full sized deck. Of major concern is the steel support bracket across the top of the dash which you'd have to likely chop out.
I had a hard time fitting the Z2 in the factory radio spot to begin with. That's only because I've got a good 3,345 lbs of wire back there. My suggestion, Z1 in the bottom, 7"er in the cubby
