Is this possible...??
Old Jul 14, 2003 | 03:24 PM
sean6tt's Avatar
sean6tt
Default Is this possible...??
Well basically i want to put some subs (two) in the z because the well the Bose system is not satisfying.
I want the best sounding system without compromising space. I know the best space saving spots are in the stock bose location but i have heard they dont sound as good as bouncing it off the glass.
And the large enclosures in the trunk seem to take up alot of space.
My idea is to build into the structure behind the seats 2 subs(10" or 12")??
I came up with this little crappy photoshop.
Do you think it is possible to do something like this without compromising alot of space.
Old Jul 14, 2003 | 05:59 PM
alphared's Avatar
alphared
Default Re: Is this possible...??
There are a few that has two subs in between the rear speakers and the brace. Now if you mean in the same space as the rear speakers are, you in a whole lot of work. Theres alot of metal to cut to fit the sub and an enclosure.
Old Jul 14, 2003 | 07:11 PM
sean6tt's Avatar
sean6tt
Ok thanks thats the feedback i was looking for. I was actually looking to buiild into the spot where the speakers are. But looks like alot of work.
I have seen alot of enclosures that go between the strut brace and rear speaker section, but seems to take up alot of space.
The one i am looking at is something like this....but only with 2 subs.
Old Jul 15, 2003 | 11:38 AM
johnsZ's Avatar
johnsZ
Default subs
I like your "photoshop" idea- although it will be a lot of work...
One caveat- if you do this, you will likely clobber the existing rear speakers due to transient pressure build-up with high levels of bass (unless the rear section is really not air tight I do not know for sure, sorry) - so, use a tuned-port vent (you can get them from Parts Express in Ohio) to relieve the pressure and also get a boost in the bass if you tune to the correct port length (you can figure this out by trial and error, or by reading any of the decent car audio books at Barnes and Noble or other bookstore).
Old Jul 15, 2003 | 05:14 PM
sean6tt's Avatar
sean6tt
is it possible to get an enclosure like this one...which someone made a similar one in a group buy...
get one like this and turn it verticle like the above picture.
from the front of the strut bar...How deep is the exact depth of this picture... does it go althe way to the rear speakers/seats portion
Thanks
Old Jul 21, 2003 | 09:14 PM
hndumafia's Avatar
hndumafia
you can get that custom box for between the rear seats and the rear strut bar from Nazar at custom car alarm and stereo...6033821801 is the number there
Stayka
Jan 7, 2015 01:24 AM
surfo
May 29, 2014 02:39 PM
shyun1250
Mar 7, 2012 02:02 PM
