Stock Stereo outputs? 04.5 Base
I was curious if anyone knows if there are any outputs on the back of the stock deck in the 04.5 base model. Amp lead and rca output?
Just got my Z a month or so ago and don't have the cash to dish out for a new HU until next month but I'd like to get my amp and box wired until then.
Thanks for your time.
No, RCA out's on the stock headunit. I would suggest to wait and upgrade everything at one time. If you use the stock headunit, you will need to install an "line out convert.",,,or Rockford 3sixty, or JL cleansweep. If you wait and install a new headunit, your amp and sub set-up,,,you will be much happier. Just my opinion. I hope this helps,,,keep us posted on which set up you go with and list of equipment. Good luck and congrats on your new Z.
350Z_Al
Oct 29, 2020 07:44 PM
