Phoenix gold amps
Old Jun 18, 2008 | 03:26 PM
codek's Avatar
codek
Default Phoenix gold amps
I'm looking at a Phoenix Gold ZX450 for $250 to go with a stealthbox I picked up.
What do you guys think. I'm an audio newb. Also looking for some suggestions on components go with this setup
Old Jun 19, 2008 | 05:21 AM
350zspl's Avatar
350zspl
the amp does not motivate me
sorry
Old Jun 19, 2008 | 06:01 AM
ofl0926's Avatar
ofl0926
sorry
hey listen to this man here... he has been helping pick and choose stuff for my audio set.
hey what dont you recommend some amp brands, from the budget brand to the high stuff so people have an idea instead of guessing
Old Jun 19, 2008 | 06:42 AM
350zspl's Avatar
350zspl
the PG amp is not bad
you can use it, if you already have it
if your asking if you should buy it for $ 250 , i would say no don't run out and buy it
what size sub are you buying
how many
what impedience
what make sub do you want
sealed or ported
what type music do you like
what is your budget
what are your plans as far as HU, front stage, etc
Old Jun 19, 2008 | 07:50 AM
codek's Avatar
codek
how many
what impedience
sealed or ported
I have a 350z stealthbox with Two JL 10W3v3-8ohms and am building around these subs
http://mobile.jlaudio.com/products_s...hp?fit_id=1416
what type music do you like - punk rock, hip hop, techno/trans, acoustic guitar
what is your budget - 200-500 on an amp, want an all in one amp, preferably
what are your plans as far as HU, front stage, etc - current Alpine CDA9855, probably will go for a excelon, maybe .. a DNX8120... that will be a stretch
I'm also looking to replace stock front/back speakers, I want to get something used budget 150-250 for fronts, 100 for back
I just want a good system, don't need a great system, I'm mainly doing this because the stock speakers in the Z are so horrible. I want it to be balanced and I'm not gonna try to wake up the neighbors with it. Mainly I want a clean system. and am looking to spend about a 1000 overall on mostly used gear. I'm against buying new gear.
Should I go with old school gear, I hear that they used to make better everything in the 90's
how many
what impedience
sealed or ported
what is your budget
Old Jun 19, 2008 | 07:55 AM
codek's Avatar
codek
NOGO on the PG's? I heard these are good amps for that price. Are they ok? Or are they too old?
Old Jun 19, 2008 | 08:32 AM
350zspl's Avatar
350zspl
if you want to drive those subs to their max , they can share 1000 rms
i might suggest a 5 channel amp so you can get it all in one , but yeilding 1000 rms on the dedicated sub channel off a 5 ch ain'y easy
let me think a moment
Old Jun 19, 2008 | 08:33 AM
ofl0926's Avatar
ofl0926
personally i have reading and have heard a lot of people using elemental design. there are a lot of builds on the forums with these amps. check them out, plus they are not expensive
www.edesignaudio.com
Old Jun 19, 2008 | 12:05 PM
350zspl's Avatar
350zspl
i would run a Zapco DC650.6 before the PG
Old Jun 19, 2008 | 01:30 PM
codek's Avatar
codek
I was looking for an amp around 200-400 range. The Zapco's retail for 1100-1400. Are they really cheap used?
Old Jun 19, 2008 | 01:44 PM
codek's Avatar
codek
can't find them anywhere. any other options? I might be ok with a 4 channel amp. I don't care about the rear speakers for now. I might just power them with the head unit for now.
Old Jun 19, 2008 | 01:52 PM
Pin69's Avatar
Pin69
Hifonics maybe?
Old Jun 20, 2008 | 08:33 AM
350zspl's Avatar
350zspl
http://cgi.ebay.com/ROCKFORD-FOSGATE...QQcmdZViewItem
these are really great under $500
Old Jun 20, 2008 | 09:26 AM
THEDUKE's Avatar
THEDUKE
The main issue with that box is that is is wired up to run at 4OHM. Most Mono/Bass amps are made to work at 2OHM. If you run most of those amps at 4OHM you automatically cut the power in half. You best bet is the use a 2 channel amp and bridge that to run a 4OHM load. This will give you that best results. Also that box is really rated at 600 watts rms and 1000 max. The 600 watts is a more realistic number you should look at.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
tkuntz
Wheels Tires
Oct 3, 2015 05:58 PM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
