2003 Nissan 350z with navigation
Old Aug 6, 2008 | 04:58 PM
Roper215's Avatar
Roper215
Default program
Originally Posted by Spike100
^^ It’s probably because some of the most recent copy-protection libraries defeat the current DVD duplication software applications. I’m using some of the new CP software libraries, and they are effective blocking current DVD replication applications.
It’s really a continual project/battle… new CP methods against DVD duplication applications. For now, the new CP methods are winning, but the replications programs are working to defeat the new CP algorithms. Of course, next week… all may be completely different.
--Spike
the original DVD X-Copy would work, but it's unlikely you have it b/c they went under several years ago, but it defeats the 360 protection.
Old Aug 6, 2008 | 06:49 PM
jwillard0201's Avatar
jwillard0201
When I purchased my 06 I just assumed the dvd in the nav was legit and didnt find out till after I downloaded and burned 7.3 that the one already in my car was a copy as well. Copies work fine in my unit.
Old Aug 6, 2008 | 07:18 PM
Fusionrace's Avatar
Fusionrace
I think the 2006-2008 versions are different than the ones found in the 2003-2005 350z's
Old Aug 6, 2008 | 07:50 PM
Spike100's Avatar
Spike100
Something else to consider… older disks can be copied with older replication software, but newer replication applications may have problems with older disks. That’s simply because the CP inside the disk is older, and newer replication programs don’t always handle older “Bozo” algorithms.
Something I always do is using a “drop-dead” date. I must do this since my software is for the healthcare industry and must respect HIIPA mandates. In my case releasing old software exposes my company to significant fines when it doesn’t match current Federal healthcare requirements. So it isn’t about CP, but mostly to meet industry standards (keeping my clients current).
This same concept is applicable to maps from NAVTEQ and Tele Atlas, blending with application software from many companies (e.g., Garmin, Magellan, etc.) licensing the data. The companies providing data need to protect their product as well as insuring it runs under the most current application software. You should expect legitimate “drop dead” dates on the replication side for these products.
If you use a replication application to copy a Navigation DVD, and it fails, then try this:
Quit all allocations, and reset your computer’s clock to 12 months or more previous to the current date. Then run the replication software to copy a commercial DVD.
That may not work, but it’s certainly worth trying if you are unable to copy a DVD.
--Spike
Old Aug 14, 2008 | 11:33 AM
wasuber's Avatar
wasuber
I'll try to make a copy with my slysoft anydvd, maybe thats the ticket?
Old Sep 20, 2008 | 09:00 PM
Vigorous's Avatar
Vigorous
Updates? Anyone make a working copy? I need on asap, Thanks!
Old Sep 22, 2008 | 06:54 PM
Spike100's Avatar
Spike100
^^ Here is what I think is going on when trying to duplicate navigation disks and use the duplicated disk with a different GPS device:
The device’s ROM chip holds a binary string that must correspond with a string in the disk’s header file. If the two do not matchup, the duplicated disk won’t work. The manufacturer’s reason for incorporating this feature goes beyond copy-protection, and extends to insuring that new disks work with older devices, and the reverse (preventing the user from running incompatible components). The string probably contains a serial number and a date/time stamp. It’s likely the same values are imbedded somewhere else in the header record, but in an encrypted format.
And, that is why you cannot simply duplicate a navigation disk and expect it to work.
--Spike
Old Sep 22, 2008 | 07:17 PM
SirSpeedyZ's Avatar
SirSpeedyZ
^^^ I hope you are wrong, why would the OP's orginal disc work in his car if that were true, I doubt it is THAT complicated, seems like a problem with copyrights. Hope someone can get this working, I would love to be able to actually use my navigation!
Old Sep 22, 2008 | 07:44 PM
Spike100's Avatar
Spike100
^^ You are correct. It’s not complicated, but instead “protective.” In fact, it’s meant less as copy-protection and more as consumer-protection. The best scenario for a device and its companion software is an arrangement that insures they work flawlessly together. You do this by installing “keys” in both components (the device and its software) insuring that only compatible pieces operate together. Since the “keys” are not designed primarily as copy-protection, you can expect random success (and, that is what we see from some reports).
Notice how there is from time-to-time someone who posts here offering an inexpensive duplicated disk. There are a couple of positive reports from “buyers,” and then it “goes cold.”
I really do believe that some of the people offering duplicated disks believe they will work. Of course, they are naïve, as well as are the buyers of these disks.
--Spike
Old Sep 27, 2008 | 08:57 AM
kroe's Avatar
kroe
You guys are overthinking this.
There isn't any fancy copy protection on these disks. The DVD drives for the nav unit are picky. The disk I finally got to work is a memorex DVD+R DL.
Please do not PM me about copying nav disks, I won't do it. The only reason I copied mine is to try and tinker with it (want to make that stupid nag screen go away, no luck so far).
Old Sep 27, 2008 | 04:54 PM
Spike100's Avatar
Spike100
^^The DVD disk has a string in its header record that must match the ROM in the navigation device. It’s not so much copy-protection as insuring the device and the disk are compatible and work together.
Your experience was positive, but that’s because you had compatible pieces.
--Spike
Old Sep 27, 2008 | 09:33 PM
kroe's Avatar
kroe
Yes, the software version needs to match the map disk version. When you buy a new version you get the map disk (DVD-DL) and the program disk (CD-ROM).
Both are easily burnable if you can find disks the drive likes (CD disks are easy, it is picky with the DVD-DLs).
Old Jun 4, 2009 | 06:27 AM
Pfinder2005's Avatar
Pfinder2005
I managed to back up my original copy version 6.7 and it works perfectly.
Let me know if you need help.
Old Jun 4, 2009 | 03:39 PM
Peteski's Avatar
Peteski
Must be Vacation time for everyone and people need an updated disk because 6 out of 10 replys to posts today are for Nav disks. Good thing most Navigation is built in on the new units of quality and can update online.
Old Jun 4, 2009 | 05:00 PM
Spike100's Avatar
Spike100
^^ Good point!
I was thinking the same thing. The better (new generation) GPS devices support downloading your map database updates from the manufacturer’s website, and installing the update using a USB flash drive or SD card.
DVD updates are awful since they are expen$ive and depend upon slow shipping.
This is a good argument for going with a remote GPS black box since this unit often costs less than a DVD update (and updating costs much less and is instant).
--Spike
Siqcology
Sep 18, 2019 01:45 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
hardkicks
Sep 20, 2015 12:28 PM
EnjukuRacing
Sep 11, 2015 08:30 AM
