interior fuse box
Old Dec 7, 2013 | 02:09 PM
l2iceman's Avatar
l2iceman
Originally Posted by xxxlino
Which fuse would be good to tap into for constant power even when car is off and keys are pulled? Or should i just tap into my power cable coming from my battery to my amplifier?
I wouldn't tap into constant power.. Your battery may drain before your next drive. There's also this thing you can buy that powers as long as the volt is still 12v or whatever and as soon as it dips below it'll stop power to that device in order to prevent the battery from being completely drained.
Old Dec 7, 2013 | 02:23 PM
ALO8's Avatar
ALO8
yes i forgot to mention that is what i am going to connect a power kit that turns off power once volts drops below a certain amount. But i need to connect to constant power. i just dont know if it makes a difference tapping into a fuse or amplifier power cable
Old Dec 7, 2013 | 08:03 PM
l2iceman's Avatar
l2iceman
You can tap into the yellow wire from the head unit harness, this is constant power and right in the middle of everything
Old Dec 7, 2013 | 11:05 PM
ALO8's Avatar
ALO8
Originally Posted by StreetOC192
If you wire at the fuse box, PLEASE tap in on the PROTECTED side of the fuse, not the HOT side of the fuse.
how would i figure out the protected side of a fuse that is in the fuse box? im planning on using this add-a-fuse thing in a fuse that always has power
Old Dec 9, 2013 | 03:08 PM
ALO8's Avatar
ALO8
anyone know if I can put the add-a-circuit into a 15amp fuse slot? The instructions say 10 amp max but im not sure if they mean 10 amp max for the new accessory im adding or the fuse im tapping into?
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
