Amp Suggestions
Old Jul 25, 2008 | 08:18 PM
JonnyRod's Avatar
JonnyRod
Default Amp Suggestions
I'm going to be purchasing the FI Q12, but I need to know what would be the best amp to pair up with this sub. Its going in a ported 2.27 cubic foot enclosure. Currently I have a Memphis 16-MC1500D...
MClass Series
1 x 750W @ 4 ohms (0.75% THD)
1 x 1500W @ 2 ohms (1% THD)
S/N Ratio: >100dB
Freq. Response: 10Hz ∼ 650Hz (± 1dB)
Same board as Memphis 16-ST1500D
Would this be a good pair? I just want the best sound quality but under $400 for the amp. Someone else recommended the Hifonics TXi 1008D
http://www.sonicelectronix.com/item_...08D.html#specs
I also need a 4 channel amp for my mb quart RCE216 6.5's...
I'm just lost right now so any suggestions would be helpful
Q12
DUAL 1 | DUAL 2
Fs: 28.4 Hz | 27.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 05.39 | 5.63
Qes: .49 | .48
Qts: .45 | .44
Mms: 211g | 231g
Cms: 0.15mm/N | 0.15mm/N
Sd: 481cm^2 | 481cm^2
Vas: 48.3 l | 48.3 l
Spl: 85.4dB 1W/1m | 84.8dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: .8-1.5 cuft
Ported box: 1.8-2.5 cuft @ 28-33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 7.000”
Displacement: 0.16cuft
Old Jul 25, 2008 | 10:00 PM
B5I8's Avatar
B5I8
Contact 350zspl and see what kind of price he can get you on a Sundown SAE-1000D. This is actually the amp FI will recommend that you use.
Old Jul 26, 2008 | 05:46 PM
JonnyRod's Avatar
JonnyRod
bump...
Old Jul 27, 2008 | 09:17 AM
JonnyRod's Avatar
JonnyRod
man usually i can get some helpful responses right away...you guys are killin me! haha i'm still waitin for 350zspl to respond about the amp...
Old Jul 27, 2008 | 04:22 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
Like I said before if tuned correctly that amp is good I recomend that if you get this amp set the gain low....you won't need to set it that high with that sub anyways
Old Jul 27, 2008 | 05:31 PM
chavoush's Avatar
chavoush
I went with a MD1D US amps merlin, no regrets, on a q10 wired at 1ohm. Also got alpine pdx 2.150 for my fronts, again awesome amp. I almost went with an Eclipse XA2000, i've heard great things about it, and has same technology as the PDX, i was just able to get the pdx for the same price. They have the Eclipse XA4000, which would give you 4 channels.
Old Jul 27, 2008 | 06:07 PM
JonnyRod's Avatar
JonnyRod
ok thanks guys...keep em comin
Old Jul 28, 2008 | 04:59 AM
350zspl's Avatar
350zspl
will check my cost on the 1000 and PM you back $
Pleask
Dec 21, 2021 03:17 PM
ablaine
Nov 29, 2016 10:13 AM
