Anyone here know a lot about amplifiers?
Old Oct 10, 2008 | 05:09 PM
Spork's Avatar
Spork
Default Anyone here know a lot about amplifiers?
I found an old Scosche 2-channel amp I had stashed away in the basement because it didn't work. It kept blowing fuses, and it still does.
I used a multimeter to check for continuity, and my 12+ and GND terminals have continuity (the multimeter beeps when I touch both terminals).
So the amp is apart and I'm at the board. The soldering doesn't look too neat, and there appears to be fingerprints on the backside, though this is the first time I opened it.
Is this something I can fix by cleaning up some soldering points? Or should I not waste my time and scrap it?
Old Oct 10, 2008 | 05:31 PM
seekndestroy19's Avatar
seekndestroy19
scrap it
Old Oct 10, 2008 | 07:13 PM
Spork's Avatar
Spork
Alright here's another.
Found another old 1000watt sony 2/1channel amp in my basement. It turns on, but it goes straight to protect. New fuses, good voltage, etc. Any ideas? Junk too?
Old Oct 10, 2008 | 09:24 PM
VENOMSZ's Avatar
VENOMSZ
Scrap it.
Be safe, and buy a new amp.
Old Oct 10, 2008 | 10:14 PM
Spork's Avatar
Spork
Alrighty.
Thanks for the help guys
Old Oct 10, 2008 | 10:19 PM
Mike Wazowski's Avatar
Mike Wazowski
scrap them and send them to me....
Old Oct 11, 2008 | 12:15 AM
Spork's Avatar
Spork
Was that a serious remark USN?
Do you know something I don't?
Old Oct 11, 2008 | 12:20 AM
orgasm_donor's Avatar
orgasm_donor
Sony and Scosche huh?
Those are really bottom of the barrel.
Old Oct 11, 2008 | 12:26 AM
Spork's Avatar
Spork
I got them for free a couple years ago
Just don't want to scrap something that's possible to fix, ya know?
Old Oct 11, 2008 | 08:38 AM
Mike Wazowski
I want to make a robot and could use those as parts......
Old Oct 11, 2008 | 08:53 AM
chuquison's Avatar
chuquison
sex bot?
Old Oct 11, 2008 | 08:58 AM
Mike Wazowski
Originally Posted by chuquison
sex bot?
ssssshhhhhhhhhhhhhhhhhhhhhhhhhh don't spill the secrets... oh thanks for the info also. Is spanish required though?
Old Oct 13, 2008 | 03:11 PM
seekndestroy19
hahaha
Old Oct 17, 2008 | 12:53 PM
KPierson's Avatar
KPierson
It sounds like a power supply issue on the first amp and an output issue on the second amp. A lot of times both failures will result in heavily damaged components on the circuit board. The power supply is typically right by the power/ground terminals and usually has a large transformer - if the transformer is shorted out the chances of fixing it with the exact replacement part would be slim.
The output is almost always a MOSFET - the transistor looking thing attached to the heat sink. A lot of times when they short out they take some large power resistors with them so there is usually lots of visual damage.
Old Oct 19, 2008 | 06:36 PM
dryseals's Avatar
dryseals
Anything can be fixed, it depends on how much you are able to do. I've been in the electronics world for over 30 years. Most things are pretty simple to fix if you can find a schematic, without the schematic, it's easter egging, or very time consuming.
Unless you have the skills to do it yourself, thyen you are at the mercy of someone else. Sell them as scrap on the bay.
Old Oct 19, 2008 | 06:38 PM
Spork's Avatar
Spork
Alright thanks guys.
KPierson, thank you much for that info. I appreciate it a lot.
New thing with the Sony amp though...
It turns on and the power LED stays green, but it won't play sound. Same problem as you described?
apex locator
Jul 23, 2021 02:27 AM
Rev_Night
Nov 7, 2020 06:00 PM
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
