How to vinyl A-Pillar
Old Oct 13, 2008 | 01:02 AM
Alwyn's Avatar
Alwyn
Default How to vinyl A-Pillar
Hey guys, i've just completed doing my A-pillar tweeter pod. It's ready to be upholstered with vinyl. Is there a particular type of vinyl that i should get (type of backings)? Can someone tell me what is the most effective way of doing it?
at the moment, i usually upholster MDF wood with adhesive spray, hot glue the edges and pull the vinyl to make it conform to the shape...
is this what you guys would recommand?
Old Oct 14, 2008 | 05:24 AM
ColoradoClark's Avatar
ColoradoClark
Try these forums:
DIY
CarAudio
You will find more people who do projects like DIY A-Pillar tweeter mounts.
Out of curiosity: did you mold the tweeters to the a-pillars? What did you you?
Old Oct 14, 2008 | 07:42 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
dpending on the shape of hte A pillars, if you got too big of a curve, espeically concave, its going to be very tough to vinyl wtih any kind of vinyl and make it not wrinkle over time...
but its a normal shape relatively, you can honestly vinyl it with anyhitng, doesnt matter if its super stretch or not, the key of courese, the glue you use, anyhting thats not realy contact adhesive (yellow colored stuff) is going to rapidly break down in the heat and fall off...so i suggest contact cement for sure.
b
Old Oct 14, 2008 | 06:21 PM
orgasm_donor's Avatar
orgasm_donor
I recommend Helmeprene glue as it will not break down the backing of the vinyl. There are other glues as well that work with vinyls. Dupont and 3M both make excellent adhesives for this type of job. Spray glue in a can is a great way to have the vinyl peel off in about a week or less.
Fourplay's Avatar
Fourplay
do you have a build for this? Ive had A Pillars for the G35 for almost 6 months, im a novice, couldnt figure out how to make it work. Trying to put a tweeter and a 3"
norrix420
350Z Roadster
May 23, 2022 05:11 PM
Vigman
Nov 17, 2015 04:34 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Ricky
Mar 7, 2004 05:31 AM
