adding sub to Bose
Old Oct 19, 2008 | 08:11 AM
airborneranger's Avatar
airborneranger
Default adding sub to Bose
I am about to add a 10" kappa perfect to the bose system. I yanked the factory sub and will simply use high or low level (not RCA) to get the signal. My question is, can I tap into the rear speakers for the signal or is it filtered there? Thanks
Old Oct 19, 2008 | 10:52 PM
orgasm_donor's Avatar
orgasm_donor
Yes, the rears run at full range. Just make sure that your high/low converter is adjustable so you can level match your impedence. Also, make sure the amp's low pass crossover is switched on.
Old Oct 22, 2008 | 04:57 PM
airborneranger
thanks much
Old Oct 28, 2008 | 05:04 PM
tylerxfire's Avatar
tylerxfire
are you replacing the sub behind the seat with this or adding it in a seperate box, what is the sub behind drivers seat size?
apex locator
Jul 23, 2021 02:27 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
