KP Window module on 06
Has anyone successfully installed KP Tech's window roll up module on 06?
I'm having a hard time figuring out wires on 06.
Through using voltmeter, I figured out:
Black-ground
White-12vdc constant (no idea why it's white instead of red)
Brown-Ignition (again,,, weird)
I need to locate:
1. Door lock switch output
2. Door lock motor input
Can anyone help me find out what the above two wire color is on 06?
Thanks in advance.
Black-ground
I need to locate:
Thanks in advance.
OEMs follow no "standard" wire colors - that is why the 12vdc is not red. Nissan likes to use white for their constant power.
According to the service manual:
The key cylinder input is black/red and should be a thinner wire. Connect this wire to the KPtech green wire.
The lock actuator wire is purple and should be a thicker wire behind the speaker (inside the door cavity). Connect this wire to the KPtech blue wire.
12vdc is white
RAP is brown
Ground is black
12vdc is white
RAP is brown
Ground is black
12vdc is white
RAP is brown
Ground is black
12vdc is white
RAP is brown
Ground is black
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
