Why disable tweeters when upgrading component speakers?
Old Aug 21, 2003 | 08:36 PM
afr0puff's Avatar
afr0puff
Default Why disable tweeters when upgrading component speakers?
I've noticed that a lot of people are disable their factory tweeters when upgrading their component speakers. Why disable and why not upgrade tweeters also?
Old Aug 21, 2003 | 08:45 PM
alphared's Avatar
alphared
well some disable (including me) them because install speakers with tweeters on it. A few replace the stock tweeters. If you don't disable them it don't sound right, its alot of treble.
Old Aug 22, 2003 | 06:50 AM
BrickydZ's Avatar
BrickydZ
Default Tweeters?
The problem is more of control of the tweeter, than anything else. When you get a set of AM speakers they will be designed to give you the sound that you hear in the store, with the basic hook up.
If you take power from the speaker wire with no addiiional control, then you in essense pump up the treble. Along with the placement of the tweeter, very close to ear level, it will make a the treble to much. Anytime you get a spike in the treble, like a David Lee Roth howl or a frantic guitar solo, the tweeter will just load up a lot of treble, and cut right thru the rest of the mix.
It is just better to unhook them,and leave them in place, and let the AM speakers do what they do.
I rode with my tweeters on for about a month after my install.
Finally decided to get them turned off last Satuday. It made a world of difference. Before I was always fiddling with the treble, or getting ear aches. Now much better. I should have done it before.
Have a nice day, and enjoy.
Old Aug 22, 2003 | 06:56 PM
Doc1111's Avatar
Doc1111
I just had a new system put in recently and told the installer to keep my stock tweeters. I usually like a bright sound but this was too much. i had the guy unhook them and it made a world of difference. I replaced the stock door speakers with coaxials so essentially, I had 4 tweeters. Too much...
Old Aug 23, 2003 | 06:23 AM
SeanRod's Avatar
SeanRod
What about after market tweeters or after market tweeters with crossovers. Are you guys getting the same results, Too much treble?
Old Aug 23, 2003 | 05:32 PM
drw's Avatar
drw
No problems. I think the best solution is probably to replace factory components with aftermarket components. Thats what I did and they sound great.
Old Aug 25, 2003 | 10:15 PM
msims's Avatar
msims
Why couldn't the tweeters be rolled off (deadened) with a crossover?
3vilbunny
Jul 18, 2017 05:10 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
