Wiring ques for guys that have radar
Old Aug 24, 2003 | 09:13 AM
gooters's Avatar
gooters
Default Wiring ques for guys that have radar
I have researched the topic and will be hard wiring my new Escort 8500 by running a phone cord from the mirror area down the A-pillar and into the fuse box. I have never wired a thing in my life, but I AM pretty handy...just a couple quick questions.
1. What size fuse did you guys use?
2. Do you just tie the fuse into the wire inline near the fusebox?
3. Does the fuse tie in with both ground and hot wire?
4. How do you tie the hot wire into the accesory location in the fuse box?
5. Just connect the ground wire to a chassis screw or bolt right?
Thanks for the help guys, I know I can get the wire in the right place...just want to know what to do with it when I get it there!
Old Aug 24, 2003 | 01:24 PM
gooters's Avatar
gooters
Okay...I think I have found a thread that answers ques. numbers 2, 4, and 5. Just to double check...
you only need a fuse on the hot wire right?
Also, what size inline fuse did you 8500 users use?
I can't wait to install my birthday present to myself! I get it FedEx tomorrow
Old Aug 24, 2003 | 05:17 PM
FLY BY Z's Avatar
FLY BY Z
I just wrapped the hot wire around one leg of the cig lighter fuse and grounded the neg wire to a bolt under the steering wheel (all the way down and under - a few inches from the fuse box but not in the fuse box area). It works like a charm.
Old Aug 24, 2003 | 07:21 PM
toykilla's Avatar
toykilla
Default Re: Wiring ques for guys that have radar
check the manual.. i did not use a fuse
yes the fuse will be inline on the hot wire
only the hot wire
i soldered all wire connections and tied into the main accessory wire going into the ignition
yes, all the metal in the car (if touchiing chassis) is ground and can be used.
Old Aug 26, 2003 | 05:03 AM
gooters's Avatar
gooters
Thanks Josh (and Potato), I got it! Took a few minutes to find a grounding location that I liked, but it sure was nice cruisin' to work at 90+ mph this morning, helped make up for my late start!
Obadabot
Jun 18, 2023 11:31 PM
Alexreyes
Sep 30, 2015 11:30 PM
