myZR ate a CD
Old Dec 12, 2008 | 10:20 AM
04redline350's Avatar
04redline350
Default myZR ate a CD
so i was loading CD's into the changer, and slot1 decided it was hungry, when i try to eject the CD it just stays in there, and i can't load anything into it because obviously there's a CD there, my question to you Z guru's is if my only choice is to completely dissasemble the dash and H/U to get to it or if there's some kind of trick I can pull to manage to get this SOB out....thanks in advance, and yes, i searched, found how to take out the console and dash, but no topic related threads
Old Dec 12, 2008 | 01:18 PM
orgasm_donor's Avatar
orgasm_donor
Common problem with all in dash cd changers in general. Unfortuantely 9 times out of 10, there is a broken belt or spring within the deck that is preventing the cd from being ejected. Parts can be expensive but the labour is a real kick to the junk. Buying a used deck or replacing it with an aftermarket one is almost always your best option. Repairing the deck is rarely financially beneficial.
Old Dec 12, 2008 | 01:24 PM
fallenromeo's Avatar
fallenromeo
*nom nom nom nom*
Old Dec 12, 2008 | 02:47 PM
Spike100's Avatar
Spike100
Good answer... As you point out, repairing the device isn't a good option since it's expensive and the problem will return.
I prefer remote changers since they use a cartridge and are more reliable.
--Spike
Old Dec 14, 2008 | 08:07 AM
04redline350
well, for whatever reason the problem fixed itself, but yes we are looking into something more reliable as I have personally had all of the problems mentioned in orgasm_donor's post, but for now this unit is doing it's job until i can find something that'll better suit my needs
sfarrah
Jul 11, 2005 03:10 PM
Coz@CZP
Dec 6, 2004 05:13 PM
SunsetZ
Apr 3, 2003 05:32 PM
