How do you pair an amp to a sub?
I've looked and i can't find anything on here or google. Could someone explain pairing and amp to a sub in regards to wattage, ohms, ect. I have an idea but I need some things clearified. Thanks.
I have a JL audio 300/2 amp http://www.woofersetc.com/index.cfm?...Product_ID=244 what sub would be good to pair with it? i'm thinking this would be a good choice http://www.woofersetc.com/index.cfm?...roduct_ID=2895 any thoughts?
thanks for link. there's a lot of good info there. but specifically...
I assume you're going with a single sub? If so that is a good set up. 4 Ohm DVC wired to a 4 ohm mono load on the amp will produce the amps max power at a safe load and will be good enough for that sub.
yes i am going with a single sub inside a zenclosures box bridged to the amp. all parts should be here next week and installed next weekend. I can't wait. phase two is almost here!!!
phase 3 is components, reverse camera and push button start. Thanks for the help.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
