Question on installing components..
Just need some clarification before I install my components and amp this weekend. I bought like 25' of speaker wire so hopefully im good.
When installing components, do they only play off of the amplifier? Im asking this, because im sort of confused on the wiring.
It goes amp - crossover - midrange + tweeter?
By doing this, that would mean the components are only played off the amp, and everything is ran though the amp.
I just dont know what happens to the stock speaker wires? Meaning, does the stock harness just get taped up? Or, do I splice the wires, run them to the speakers and then run new speaker wires to the crossovers from the midrange?
I just need some help with clarifying. Thanks.
I wont be doing that, if I find I need to, ill have a shop do it. I just need clarification on some things. When swapping the front midranges, where do the stock speaker wires with the grey clip go to? Do they go to the new speaker?
Heres what I know: I run speaker wire from the amp, to the crossover. Then, from the crossover to the mid range, and crossover to tweeter. Now, with that said, where does the stock speaker wiring (WITH THE GREY CLIP THAT WAS ATTACHED TO THE OLD SPEAKER) go to? Does it go to the new midranges, along with the wiring from the crossover?
Input Woofer Main Twtr Image Twtr
Amplifier to Input
Woofer on X over to midrange
Main Twtr on X over to tweeter
What happens to the stock speaker harness that is connected to the stock speakers via a grey clip that is removed when installing new speakers?????
If I didnt have an amp, then I would just splice into the stock wires and connect them to the Input on the X over, but obviously im using an amp, and dont know where the stock speaker wires go.
Amplifier to Input
Ok Lazarus, ive got that down. Now, the answer to this question is what I have been seeking: What is the stock speaker wire(s) connected to when installing components? If I am running all new speaker wire through the diagram u just showed, where does the stock speaker wire come into play? Where is it connected? Is it taped off??
I dont get where the stock wiring comes into play with the components??? Thats what im TRYING to figure out. I will be running 16 ga speaker wire from the amp to the crossover and from the crossover to the mid and tweet, I dont understand where the stock wiring is going to be connected?
Workshop12
Mar 23, 2020 01:45 PM
