Amp dead?
Old Jan 15, 2009 | 10:32 AM
Nexx's Avatar
Nexx
Default Amp dead?
I had my sub box disconnected for about 6 months and everything was working fine before then. Now after reconnecting the wires back to the enclosure I get no response from the sub. Being the audio newb that I am the only thing I could check was to check if the amp was getting power which it is. I also double checked the output cabling to make sure it working. Any ideas what could be up? Is there any sort of reset or anything on the amp I could try, lol. Help a newb out!!
Sub: JL 10W6V2
Amp: JL 250/1 Mono D Class Slash series.
Many thanks!
Old Jan 15, 2009 | 11:42 AM
Get_Zwole's Avatar
Get_Zwole
is it making noise or is the light on?
Old Jan 15, 2009 | 03:04 PM
Nexx's Avatar
Nexx
not making any sort of noise but yes the green light does light up.
Old Jan 24, 2009 | 02:17 PM
xKennie's Avatar
xKennie
the lights on so thats good. you sure you have the sub wired correctly ( + to + and - to - ) also if you have a voltage reader check the power and ground to make sure its a 12.4 i believe or 12.6 reading and then check the remote control turn on cable to make sure that is reading the same voltage. put the positive terminal on that cable while you put the negative terminal on the ground cable. if all readings are good, perhaps theres a subwoofer turn on feature on your headunit? (not sure if your running aftermarket or factory) also check your rca cables to make sure they are in all the way and in correct position.
lmk if your still having problems.
Old Jan 24, 2009 | 02:29 PM
adamtaylorpcb's Avatar
adamtaylorpcb
test the sub with a multimeter for ohm load and make sure its still good.
work from the problem backwards checking stuff
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
Depravity
Oct 1, 2015 04:49 PM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
