Grounding question?
Old Sep 2, 2003 | 08:07 PM
Shadowrwr's Avatar
Shadowrwr
Question Grounding question?
I just wanted to know, im hooking up an external amp to my bose system. Is the bolt that is under the rear carpet that has a hook on it (top right side of carpet in front of bar), a good spot to ground if i sand it down? Or where would a better spot be?
Thanks for anyones help.
Old Sep 2, 2003 | 08:15 PM
ares's Avatar
ares
Veteran
how many watts you talkin about? I think 2 or 300 is best grounded straight to the battery, the chassis is only so good of a conductor.
Old Sep 2, 2003 | 08:53 PM
Horizon1's Avatar
Horizon1
quite honestly, any bolt you find on the chassis on the cage is a decent ground. i recently installed my jl 500/1 and 300/4...and i just ended up just using a "T" block and ground it to one of the bolts holding down the bose sub frame. Also, you generally want your ground as short as possible to avoid "ground loops" which can wreak havoc on your speakers...."unwanted noise, alt whine, etc"
so yea, if you can, the ground from your amp should be as short as possible.
o yea, and by chance, i have had crystal clear sounds from my speakers with no alt whine at all by grounding the amps at that point i mentioned above. (i didnt sand it either) hope this helps, and good luck!
Old Sep 3, 2003 | 05:41 AM
Shadowrwr's Avatar
Shadowrwr
Thanks for you help. My amp is about 1 ft away from the bolt I was talking about and it seemed like a nice idea. Thanks agian.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
