Best SQ Subwoofer?
Old Feb 10, 2009 | 06:48 PM
whitemikecn's Avatar
whitemikecn
Default Best SQ Subwoofer?
OK guys I am looking for a SQ Sub that I can push if I want to.... I have the DLS A6 is the amp that will be running it and if you need specs for it here they are:
Number of channels 1
Amplifier class AB
Output power in 4 ohm 500 W
Output power in 2 ohm 870 W
Mono bridge mode 4 ohm N/A
Output power in 1 ohm 1200 W
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 125 Hz
Input sensitivity 0,2 - 7 V
Input impedance, high level N/A
Input impedance > 10 kohm
High pass filter Subsonic: 25 Hz
Low pass filter 50-125 Hz
External cooling fan terminal 1
Dual DC inputs 1
Remote base level control 1
Remote phase shift control 1
Integrated fan 1
Power consumption (idle) 0,6 A
Power consumption (max) 140 A
Rec. power cable Minimum 2AWG / 33 mm2
Fuses 4 x 35 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight 6,2 kg ( 13,67 lb)
What 10 inch sub or subs if need be would you get if you could spend 700 for one or about 1000 if you were to run two of them? Looking for some help guys and thank you in advance.
Old Feb 10, 2009 | 06:59 PM
seank426's Avatar
seank426
Im a novice to all this still but I plan on getting a 10w6v2 after everything I've heard about it, mainly that its the best SQ sub out there. Many say better then the w7
Old Feb 10, 2009 | 07:04 PM
whitemikecn
LOL not to come off as a bad guy but I have a 10w6v2 and that is what I will be getting rid of and replacing. If you want one that has never had power run to it ill sell it to you. Send me a PM. JL Audio is overpiced for what they are and will not be in the same ball park to the subs that people are about to mention. I have a few subs in mind ut I wanna see what people say first.
Old Feb 10, 2009 | 07:09 PM
Kwame's Avatar
Kwame
My vote is for the sub I am running but in 10" Seas Lotus SW250...
http://www.mobilesq.com/shop/product...roducts_id=173
Old Feb 10, 2009 | 07:17 PM
whitemikecn
Kwame who did you order yours from?
Old Feb 10, 2009 | 07:34 PM
iamdigital's Avatar
iamdigital
I have to say for a more natural sound go with high quality 8" speakers and go with more than 2. I have had 10s, 12s, and a 15 and they are great for SPL but not SQ. Nothing will deliver a wider frequency than a good 8 or even a set of 6s for that matter. One of the nicest systems I ever heard was 4 8s in a custom enclosure. 2 were sealed and 2 were ported. sounded great but it was back by an amazing system as well.
Old Feb 10, 2009 | 07:41 PM
Kwame's Avatar
Kwame
I happened to find a great deal on ebay on a brand new set of 12s about 5 months before Seas USA even had them in. BTW, that website that I linked is run by the official US Distributor for Seas.
Old Feb 10, 2009 | 07:52 PM
whitemikecn
I agree that a lot of 8s would sound good but I would like the ability of getting some deep bass that the 8s will not provide... I am dead set on a 10 or 10s. Thanks for the imput though.
Chris
Old Feb 10, 2009 | 08:13 PM
CanadianDream's Avatar
CanadianDream
^^^^^ You need to listen to more 8's. Try the DD1508 - amazing 8" subs.
Old Feb 10, 2009 | 08:26 PM
B5I8's Avatar
B5I8
There's no question as to what sub I would get no matter what my budget was and that would be an Image Dynamics iDMax. I like SQL and this sub is probably the best of both worlds. It has a great ability to blend with the front stage and has plenty of output for people who like it loud. With good processing and enough power I think this sub can compete with the best of them.
Old Feb 10, 2009 | 09:13 PM
folgrz's Avatar
folgrz
i really liked my idq v3
different strokes for different folks
you really have to go out and hear these speakers yourself to get the best judgement
Old Feb 11, 2009 | 06:30 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Two words: Thiele and Small.
These two Australian audio engieers back in the 1960's published papers with formulas which allow a speaker builder to tailor the sound of their subwoofers enclosure. Nearly five decades later speaker manufactures are still publishing the Thiele/Small parameters. Basically you can take a given speaker motor and make it sound good or bad depending on the volume of the enclosure it's mounted in. The reason some folks have good or bad experiences with their subwoofers often has to do with their set-up and not the speaker itself: over powered amplifier, under powered amplifier (pretty common), air gaps, or a poorly designed enclosure.
Since with the Z you're got pretty few choices where to put a subwoofer it's best to work backwards and find an enclosure and then look at the speakers who's Thiel/Small parameters match. But that said most people either go with what's pretty, what's popular, or what's loudest.
Old Feb 11, 2009 | 06:53 AM
quakerroatmeal's Avatar
quakerroatmeal
Heard good things about Critical Mass UL subwoofers. Price is insane though. There's no such thing as a best subwoofer anyways in any category.
Old Feb 11, 2009 | 08:08 AM
Get_Zwole's Avatar
Get_Zwole
i would go custom box and run the si mag in 12''
http://www.stereointegrity.com/mag.php
From what i hear about it its top notch SQ and can really perform for times you want more bass.
Old Feb 11, 2009 | 02:06 PM
adamtaylorpcb's Avatar
adamtaylorpcb
my vote is for the FiQ 10, im thinking about picking one up myself
https://ssl.perfora.net/www.ficaraud...iew.shopscript
Old Feb 12, 2009 | 06:55 AM
Get_Zwole's Avatar
Get_Zwole
http://www.diymobileaudio.com/forum/...ty-mag-v4.html
review for the SI mag supposed to be awesome.
Old Feb 12, 2009 | 07:10 AM
QuadCam's Avatar
QuadCam
I was going to suggest lookign at Digital Designs also.....
yes...they make some of the loudest subs in the world, but they have sick SQ, too. I used to run a pair 9515d subs in my dB Drag Race Street setup (back in 2002)....they were so tight and quick. They put any 10" woofer to shame in they transient response and articulation. .....and I am talking about a pair of 15s!!!!!! I had the chance to compete at a show In Palm Beach....It just happened that JL Audio had their demo vehicle (with a pair of 13W7s) there. they were playing a version of Hotel California for demoing the whole system.
I just happened to have the same song ....and started to play it too. My setup was the DD 9515s powered by a (roughly 8000 watts of mmats power!!!!), vifa XT25 tweets and DD 6.5" mids powered by a vinatge ADS PQ20. with the subs turned WAYYYYYYYY DOWNNNNN to an appropriate level to match the mids/highs....this setup was beautiful. Several people A/B'd my system to the JL system as did I.....there was no comparison.
anyways......JL makes decent stuff....but they are marketing people. they haven;t gotten very big and gotten away from their Speaker Warehouse roots and pure competing. now, it's about selling lots of product!!!!
Look into Digital Designs. custom built and worth every penny!!!! You won't be disappointed.
finally, as Paul350z said.........the enclosure makes the woofer! having a true professional subwoofer specialist build you enclosure. you need to make the woofer work with the enclosure and work with your vehicle. That's what I did for years.....I was damn good at it, and really took pride in my subwoofer cabs. there really is no perfect box for all setups. find a great installer and work with him on your goals if you are really serious about sound. if you just think you need an "SQ" setup, but don't really have an ear for it.......alot of basic designs will do.....and you'll be happy.
Old Feb 12, 2009 | 08:40 AM
Renfri's Avatar
Renfri
Here is a link to a thread for the best SQ subs...
http://www.dynamicautoacoustics.com/...php?topic=42.0
Old Feb 12, 2009 | 09:43 AM
Buckeye8084's Avatar
Buckeye8084
I've been out of the game for a couple of years, but the Infinity Perfects were always high on people's list.
You cant go wrong with Sea's. They have very high end stuff.
A lot of people had I.D's too.
Old Feb 12, 2009 | 12:09 PM
adamtaylorpcb
one of the worst threads ive ever seen
how does a stroker fit the sq bill? every stroker ive heard was just spl
