06 Bose headunit will work in 03?
Old Feb 14, 2009 | 12:55 PM
jdmrwd's Avatar
jdmrwd
Default 06 Bose headunit will work in 03?
Hi guys, I am having the driver side speakers cut out problem, and I am just wondering if the problem will be solved if I just replace the headunits. I came across with an 06 Bose headunit, I just wondering if its a plug and play, or I am SOL just get a new aftermarket headunit?
Thank you !
Old Feb 14, 2009 | 03:01 PM
ocbosshawg's Avatar
ocbosshawg
Default a suggestion
best buy will hook up anything you bring them... a stock system into another car they will hook you up... the thing is they are pricey for installations but if ANY problems happen to your car that is related to the way its hooked up they will pay for all repairs and fix your system back up... GARANTEED... i had an is300 ive had done at crazy places cuz they were cheap... but best buy has always came out clean they always use top of the line wires... but i think thats the best thing to do if theres anydoubt on what you think the outcome could be.... but i mean if your trying to save money and do it yourself... i think it would work because i have buddies that install systems and the bose system should be able to handle the same wires. if you take out the old system and the speakers fit the same way then your alright..
Old Feb 14, 2009 | 03:31 PM
Spike100's Avatar
Spike100
^^ Huh!?
Old Feb 14, 2009 | 03:37 PM
Spike100's Avatar
Spike100
Thank you !
I'm assuming your car has the Bose "upgrade." The speaker cut-out you describe is a common problem (as you mention). You don't need to to replace the H/U to fix this.
If you do elect to replace the H/U, any double-din device fits the space, including OEM Bose units from newer Z's.
--Spike
Old Feb 14, 2009 | 06:27 PM
jdmrwd's Avatar
jdmrwd
--Spike
Naw... try to stay away from doing a audio set up for now, I know once I order a double din, I will say I may as well just get the whole system done. Mod bugs FAIL!
So whats the solution to fix the cut out problem?
Old Feb 18, 2009 | 09:52 AM
Lsmith9523's Avatar
Lsmith9523
The 06 headunit will not fit in the 03 Z. In 06, nissan changed the dash opening. The 06's headunit corners are more rounded than the previous years.
Old Feb 18, 2009 | 09:58 AM
Spork's Avatar
Spork
I also believe the connections are different.
dcains
Nov 11, 2015 11:36 PM
_bit
Oct 2, 2015 07:49 AM
