static in speakers
Old Feb 22, 2009 | 02:20 PM
candyman7's Avatar
candyman7
Default static in speakers
i dont know much about audio stuff and i have static coming from speakers and a little whistle noise that sounds like a supercharger. the whistle increases pitch as the rpms go up. any ideas? thanks
Old Feb 22, 2009 | 03:46 PM
adamtaylorpcb's Avatar
adamtaylorpcb
its grounded out somewhere, had the same thing in my old car and it drove me nuts
Old Feb 22, 2009 | 04:43 PM
candyman7's Avatar
candyman7
Originally Posted by dave079
Do you have an aftermarket system?
yeah the guy who had my car before me installed it. I took a look at the wiring the other day and everything looks like a mess
Old Feb 22, 2009 | 05:46 PM
candyman7's Avatar
candyman7
Check your grounds and make sure your RCA cables aren't running next to your power wires.
ill check that out tomorrow thanks
Old Feb 22, 2009 | 05:59 PM
ChuckW's Avatar
ChuckW
Start here: http://www.bcae1.com/
Start with the right hand column selection number two, read, and move to three. Continue until you understand enough to buy a soldering iron, go back to your car, and rewire that rat's nest!
Be patient. It takes a while to do things right.
Old Feb 23, 2009 | 06:52 PM
Spike100's Avatar
Spike100
I can only guess from reading your message. It could be something as simple as an inadequate wire attachment to the speaker. But (and much worse), it sounds more as though you are picking-up noise from your alternator (since the interference increases when increasing engine speed).
As dave079 mentions, it’s probably a faulty ground or poorly shielded power cables.
To fix this, you will need to expose the H/U and its wiring.
  1. Take the center console apart and pull the H/U forward so you see the wiring.
  2. If you have a lot of grounds going to various places (either to metal or other ground-wires), try relocating all the grounds (as much as practical) to a single place where you know you have a reliable ground. What you are doing with this exercise is eliminating a ground loop which can cause the problem you are experiencing.
  3. After relocating the grounding wires, and before putting the dash back together (your H/U will be sitting outside the dash but wired for power), start the car and rev the engine with your radio on. If it’s good (no noise or whining), you’re done and you can put everything back in place. This usually fixes the problem, and you probably won’t need to go to the next step (described below).
  4. If you still have noise, you must begin checking your power wires (which is a real pain). In this case you are looking for powered wires that have inadequate shielding and are in proximity to other power wires or ground wires. The bare area probably doesn’t physically touch (in this case you would blow a fuse if your fusing is correct); but if it’s in proximity and exposed, you have sound pollution. Probably the best and most simple approach here is to establish new attachments for your power wires.
Please let us know how you resolve this issue. We will all learn from your experience. I share your pain since I know how frustrating this type of problem can be. Thanks for posting.
--Spike
3vilbunny
Jul 18, 2017 05:10 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
