Amp grounding question
Old Sep 14, 2003 | 06:52 PM
ZManInNY's Avatar
ZManInNY
Default Amp grounding question
For those of you who installed your amp(s) behind the passenger seat in the glove box, where specifically did you ground it/them?
Also, if anyone has any easy, detailed instructions about how to take that glove box out, I would really appreciate it. From looking at it today and removing a few screws, it doesn't seem like an easy process and I don't want to break anything. I want to take this off to see where I may be able to ground my amp and also to be able to fit the amp underneath the 'hidden' compartment.
Thanks for any help!
Old Sep 14, 2003 | 07:24 PM
bastard's Avatar
bastard
To remove the glovebox, you have to first take off the panels on the sides of the car behind the doors, then remove the panel where the glovebox is. After that, the glovebox is held in with screws around its perimeter and two way in the inside. You also have to pop out the "secret compartment" in the glovebox to remove it. All of these parts except the glovebox are held in by snap/clip things.
There's a good ground location on the driver's side, to the rear of the seatbelt. There are two bolts that aren't holding anything on that can be seen. There may be a similar thing on the passenger side. I didn't look.
Old Sep 15, 2003 | 09:28 PM
ajk4's Avatar
ajk4
check the "350z how to's" post at the top of the this section. scroll down and you will find several links with detailed pictures and text on how to remove almost every panel in the car.
Old Sep 17, 2003 | 12:44 PM
peptidbond's Avatar
peptidbond
I used bastards suggestion. After removing one of the 10mm bolts and sanding a small spot clean of paint, I install the ground wire. Worked like a charm. I have a very solid ground. Thanks bastard (that doesn't sound right)!?!?!
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
