Pioneer AVH P4100 - anyone own one for a Z yet?
Old Jun 5, 2009 | 11:23 AM
  #41
hotfiyah's Avatar
hotfiyah
does anyone know how to play videos from your ipod on this?
just got it installed yesterday. I have the switch as well...it plays the audio, but not the video....even though the switch is flipped.
Old Jun 5, 2009 | 11:50 AM
  #42
chi350's Avatar
chi350
you might have to change the video settings...have you gotten the music videos to play off a cd/dvd disc yet? if so, what settings did you use?
Old Jun 5, 2009 | 06:12 PM
  #43
gflack's Avatar
gflack
Are you using an iPod cable from Pioneer or going through the built in USB port?
Old Jun 6, 2009 | 08:10 AM
  #44
Mr. D's Avatar
Mr. D
I can't get one of the harnesses out of the back of the radio. Any suggestions?
Old Jun 6, 2009 | 08:56 AM
  #45
Mr. D's Avatar
Mr. D
Finally!
Old Jun 6, 2009 | 12:46 PM
  #46
Mr. D's Avatar
Mr. D
Almost there, but I'm having an issue with the toggle switch. I've connected one end to the parking brake wire from the new head unit and the other to a ground in the car but I can't get the switch to work. Am I missing something?
Old Jun 6, 2009 | 01:47 PM
  #47
IbarraZ33's Avatar
IbarraZ33
i dont see the auxiliary or usb port, is it on there somewhere or is it just not there??
Old Jun 6, 2009 | 02:09 PM
  #48
Mr. D's Avatar
Mr. D
USB and AUX is on the back of the 4100.
I would call my install 50/50 success/fail. Everything works great but my damn toggle switch. I put everything back together but left the switch out in the open and will try a different switch or a relay if that doesn't work.
Old Jun 6, 2009 | 04:56 PM
  #49
hndumafia's Avatar
hndumafia
I am having this problem also. If i switch to aux1 it shows the video but it is paused, and there is no way for me to start it.
Finally I got the unit installed today. Spent way too much time on the install last night thinking I was just screwing up the wiring for the bypass relay. But figured out in about 5 minutes today with a new relay that the one I was having problems with just didn't work.
The relay used is a 30amp 12v spt automotive relay with 4 posts labeled 30, 85, 86, 87. I ended up with the relay wired a little differently than what I have seen online.
85&87 - ground
86 - remote turn on (solid blue from pioneer harness)
30 - parking brake wire (green from pioneer harness)
thanks Chi for going back and forth with me through PM.
Old Jun 8, 2009 | 10:43 AM
  #50
chi350's Avatar
chi350
np...glad it worked out.
Old Jun 8, 2009 | 10:35 PM
  #51
Tomek350Z's Avatar
Tomek350Z
trust me guys, that toggle switch sounds like a dam hassle
get the black box from ebay, ive had it over a year and i dont have to push any buttons, just tuen the car on and select what i want......
Old Jun 9, 2009 | 05:53 AM
  #52
Mr. D's Avatar
Mr. D
I got the switch working the next morning. I needed to ground it to the same point I grounded the radio.
The toggle switch doesn't bother me. If I'm riding with my wife then I'll flip the switch but otherwise I don't need it so I don't bother to flip it.
The only problem I have is the radio reception is infinitely worse than stock, but other than that I give it a thumbs up.
Old Jun 9, 2009 | 01:54 PM
  #53
hotfiyah's Avatar
hotfiyah
I haven't tried a DVD or anything yet....
but i do have the pioneer iPod cable...
but i must say....i love this deck...great quality.
Old Jun 11, 2009 | 11:01 AM
  #54
Lonewulf's Avatar
Lonewulf
Hi guys,
i'm pretty new to this forum but I just want to tell you I installed this AVH-P4100 on my 2004 350z and its awesome.
here's a link to my youtube demo:
AVH-P4100DVD on youtube
There's some distortion due to bad Camera ( Casio Exilim ). But, go for it, its a great unit. I used to have the Bose 6 disc.
Also, I had some great help from another thread, here, installing bypass switch. It's easy to setup and use.
Thanks for the help.
Old Jun 11, 2009 | 05:26 PM
  #55
Maddawg's Avatar
Maddawg
Got a p5100dvd instaled with no problem. Now backing up w/oston Accustics sl60, 65 and G110 for sub. Poer amp is Alpine PDX-5. Good sounds. You need to lace door panels anc rear strut w/accoustic packing to cut soud extra car harmonics.
Old Jun 12, 2009 | 06:15 AM
  #56
YoungBB's Avatar
YoungBB
anyone know if the audible directions from the factory navigation are retained if i swap the unit? (I just got the new unit today btw)
Old Jun 12, 2009 | 01:45 PM
  #57
YoungBB's Avatar
YoungBB
^^^^ any help? Just to keep you guys posted they didn't have the 4100 in stock so I just upgraded to the 6000 which is sweet since i could keep the in dash 6 disc
Old Jun 16, 2009 | 06:47 PM
  #58
PhatZooM's Avatar
PhatZooM
has anyone figured out how to make the time show normal ??? not just in military time i cant figure it out
Old Jun 17, 2009 | 07:30 AM
  #59
Mr. D's Avatar
Mr. D
It will only display the 24 hour clock.
Old Jul 9, 2009 | 06:57 PM
  #60
Kupalo's Avatar
Kupalo
I swear I got a 12 hour clock, I haven't paid that much attention to it but right now its 10:57 PM and that's what it says, and in 12 hours it will say the same thing.
I can't get the video to play though from an iPod, has anyone? I know you have to turn the h/u off then go into the menu and Aux1 to "iPod" instead of Video for it to work, but it doesn't play for me. I have an 30GB iPod Video 5G and have the video setting correct. TV Out is on and its set to NTSC.
I think I have everything right but I still can't get it to work. :/
