Anyway to operate headunit while in house
Old Apr 10, 2009 | 04:02 PM
seank426's Avatar
seank426
Default Anyway to operate headunit while in house
So I'm not getting my stuff installed until April 21st which is killing me cause I really wanna check my headunit and just mess around with it. Its a Kenwood DDX812. Is there anyway that I can power it with it in my house. Any help would be appreciated.
Sean
Old Apr 10, 2009 | 07:16 PM
Sean's Avatar
Sean
use your car battery, or a battery charger, or a radio shack 12 volt power supply
Old Apr 10, 2009 | 08:51 PM
Spork's Avatar
Spork
You can use a car battery and hook up the 12+, Ign, and Gnd.
Old Apr 13, 2009 | 06:00 PM
Spike100's Avatar
Spike100
It’s always a good idea to bench-test your equipment before doing the installation. That way you know it’s working before doing a lot of work. And, if it’s working before the installation, but not working after installation; at least you know you have working components and the problem is the installation and not the devices.
As Sean mentions, you could simply use a 12v battery (not great since it will run down during your tests) or one of those battery chargers with its own self-contained battery (plugs into a household outlet and continuously charges the self-contained battery so it maintains power and never dies or loses power during your testing). You should be aware that using either of these won’t provide any protection if you connect your devices incorrectly so be use to ground everything correctly and in the right order to avoid damaging your equipment. These power sources are always “hot.”
Sean’s other suggestion, a household to DC converter, is the best way to test your equipment. Here are a couple examples of these devices:
http://www.radioshack.com/product/in...ductId=2103959
http://www.radioshack.com/product/in...ductId=2103961
--Spike
Old Apr 13, 2009 | 10:11 PM
adamtaylorpcb's Avatar
adamtaylorpcb
i found a small power inverter off of an old ionic breeze and i use that
plugs into the wall and works for when im messing with head units or led's
dcains
Nov 11, 2015 11:36 PM
cashmoney03
Sep 27, 2015 05:24 PM
