Does FM mod reduce FM radio reception quality?
Old Sep 19, 2003 | 11:20 AM
mziggy16's Avatar
mziggy16
Default Does FM mod reduce FM radio reception quality?
Ever since I got my music keg and kenwood FM modulator put in my radio stations don't come in as clearly as they did previously and there is at least one station that doesn't come in at all anymore. Most of the stations are fine but there is definetly a difference in my 2 favorite stations. What could be going on and is it the FM mods fault? Is there anything i can do to fix it?
Old Sep 20, 2003 | 10:02 PM
fresno350's Avatar
fresno350
my fm mod. is from audiovox. it plugs right into the back of my HU and sounds really good. when the fm mod is not powered up, the radio signal just travels through it. come to think of it, my favorite stations are a little less receptive now it seems. maybe the signal going through the modulator degrades it a little. did you figure anything out? i would say call circuit city and ask them
Old Sep 20, 2003 | 10:03 PM
fresno350's Avatar
fresno350
make sure your fm mod is turned off when you are listening to regular radio if you have the same type i do
Old Sep 22, 2003 | 10:03 AM
mdelia's Avatar
mdelia
The FM mod I got with the Delphi SkyFi doesn't have an on/off switch that I know of. I have noticed a lack of FM radio reception on the few times I've wanted to listen to the local radio.
Old Sep 22, 2003 | 11:55 AM
Alang's Avatar
Alang
You need to install a switch in the power line to your FM mod. That way you can turn it off when you want to listen to the radio. This a common "mod" for those FM mods that don't have an on/off switch.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Tochigi_236
Sep 27, 2015 03:40 PM
