Audio Install - Front Speaker mount
Old Sep 19, 2003 | 07:57 PM
grutter's Avatar
grutter
Default Audio Install - Front Speaker mount
This might help someone out
I started to install my 6.5" JL Audio coaxial speakers. First attempt was to use the speaker mount from the factory Bose as posted on this forum. Problem is that the factory speakers aren't 6.5" so the JL Audio speaker wouldn't fit.
I used 3/4" MDF, but it wound up being too thick once I test fit the door trim. (I thought I needed more rear clearance). I wound up shaving off 3/8" so wound up with spacers 1 1/8".
I used 1/4" bolts with nylock nuts to mount after applying sound deadening.
When fitting the door trim, the nylon ribs in the bottom corners also needed to be trimmed.. an easy fix.
As a side note.. I know many of you have done audio upgrades already... but for those that haven't, you can't beleve what **** speakers the ''premium Bose" speakers truly are until you have one in your hands.. Anyone notice that the 10" sub... besides being a joke, doesn't have a magnet ? The metal mounting bracket weighs more than the sub. What a joke.
Anyway, hope the pictures help someone.
Comments ?
Attached Thumbnails Audio Install - Front Speaker mount-350z-audio-install-06.640x480.jpg
grutter's Avatar
grutter
Installed in Drivers-side door
Attached Thumbnails Audio Install - Front Speaker mount-350z-audio-install-18.640x480.jpg
Old Sep 20, 2003 | 06:43 AM
stopgo's Avatar
stopgo
This is awesome! Now I've got an excuse to go shopping for some power tools... heeee
Old Oct 1, 2003 | 11:10 AM
zridert's Avatar
zridert
Thanks for the info...very helpful. Is there enough room in there for a crossover incase I decide to go with component speakers? thanks again
Old Oct 1, 2003 | 05:38 PM
grutter's Avatar
grutter
Plenty of room to mount a cross-over. I mounted JL Audio coaxials in all 4 corners, and Kenwood tweets in the original factory location. Kenwood tweeters fit the factory location perfectly, using factory mounting bracket. There is another thread on this forum related to mounting locations for the crossovers. I mounted mine with velcro on top of the foam pad on the door panel. Other locations work equally well. There's plenty of room at certain locations behind the door panel.
bcoffee20
Nov 19, 2015 06:39 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
