Is Delphi XM SKYFI car kit any good?
Old Sep 28, 2003 | 04:52 AM
noel48's Avatar
noel48
Default Is Delphi XM SKYFI car kit any good?
Works through cassette player.Requires XM subscription. Anyone try this?
Old Sep 28, 2003 | 06:34 AM
devildogg's Avatar
devildogg
Yes! I like it very much. I mounted the Delphi in the Nav compartment. Do a search "Delphi radio install" or user "WESTPAK". There you will find a lot of information. I used the FM Modulator, not the cassette. I think it sounds very good...I would guess very clean FM. Not quite CD quality. Best of all it sure looks good in the Nav compartment.
Good Luck!
Old Sep 28, 2003 | 06:48 PM
the doc's Avatar
the doc
You'll definitely get better sound quality with an FM modulator. I've had XM for almost a year now and it's great!
Old Sep 29, 2003 | 07:58 AM
mdelia's Avatar
mdelia
The FM modulator sound quality will be better then using the tape deck, however its not CD quality. You also might notice that some of your FM stations don't come in as well after you hook the system up.
If you are also thinking of replacing the headunit, you can get one that has an AUX IN and run your DelphiUnit through that instead of the FM modulation.
Old Oct 21, 2003 | 04:51 PM
noel48's Avatar
noel48
The Delphi manual says that the cassette adapter sounds better than the modulator.I installed the Roady with modulator in my Murano and bought one with cassette for the Z so I can also use it on my G35.
Old Oct 22, 2003 | 05:19 PM
MikeW's Avatar
MikeW
devildogg........ i sent you a PM.
Juztin
Nov 22, 2015 07:03 AM
NissanZcrazy
Nov 2, 2015 06:03 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
SpartanZ32
Oct 22, 2015 09:36 AM
Upstreammiami
Sep 17, 2015 02:45 AM
