question on subs
Old Jul 12, 2009 | 02:38 PM
bogie1519's Avatar
bogie1519
Default question on subs
just wondering what would you add first. 10in sub and amp. then go back and add amp later for the rest of the system. would like to improve bass sound first is why i asked. on a budget. already installed alpine deck.
Old Jul 12, 2009 | 02:40 PM
zand02max's Avatar
zand02max
Old Jul 12, 2009 | 02:43 PM
quiksilver38's Avatar
quiksilver38
i would get a job and buy some decent components or you just planning on saving up your allowance?
Old Jul 12, 2009 | 02:51 PM
bogie1519's Avatar
bogie1519
thanks for for your sound advice,i'll consider it
Old Jul 12, 2009 | 07:07 PM
kenpo_350Z's Avatar
kenpo_350Z
If you want bass first, I guess just get your 10 and your amp. If you want the the other components and an amp then do that. Its whatever you want.
Old Jul 13, 2009 | 05:14 AM
bogie1519's Avatar
bogie1519
Thank you for an honest answer. Since i enjoy the bass sound on a system i will start there.
Old Jul 13, 2009 | 05:53 AM
cbr900son's Avatar
cbr900son
DO bass first imo. U already have speakers in doors etc. True they suck but u have 0 bass. So u are adding bass and just improving componets later on.
Old Jul 13, 2009 | 09:46 AM
rtiid22's Avatar
rtiid22
I personaly would add components first because for me the stock speakers produce enough base until they reach a volume where distortion is present. I feel like a sub would over power the stock components and would not be appreciated unless the stock speakers could play louder without distortion.
But that's just me.
Old Jul 14, 2009 | 03:23 AM
gsxrsellout's Avatar
gsxrsellout
But that's just me.
Agreed! Add components where you will get quality in sound then see if you want to add bass. I always thought that stereos sound like junk if they have a stock system and add a sub, not a very well balanced system.
Old Jul 14, 2009 | 04:23 AM
bogie1519's Avatar
bogie1519
Sorry guys i guess i did'nt make myself plain. already have alpine xm cd player with 4 alpine speakers installed but no sub. though i did unhook the back speakers like some suggested on this forum seemed to help. i guess question would be put my money first into a 10in sub and amp then check into amps late for front speakers or would sub and amp over power 2 front speakers. sorry for the novel, new at this.
Old Jul 14, 2009 | 04:45 AM
StreetOC192's Avatar
StreetOC192
Why not just get a sub and a 4 channel amp that can power the sub AND the front components at the same time?
Old Jul 14, 2009 | 11:43 AM
ProperID's Avatar
ProperID
I have to 2nd this suggestion. You won't need to amp the rear speakers, so you can use the rear side of the 4ch to run the sub. A single amp system is simple to install and simple to troubleshoot if any problems arise.
Old Jul 14, 2009 | 02:32 PM
bogie1519's Avatar
bogie1519
Thats why i joined this forum! Thanks you guys for both your ideas. Went by the local sound shop and will take your advice,all i need to do is choose a sub and i'm set. I already had everything else.
Old Jul 14, 2009 | 03:51 PM
Spork's Avatar
Spork
I ended up going components first along with a 4-channel amp and hooked up a weak mono amp for the stock BOSE sub and brought the lowpass down to 50hz.
Later down the road, I picked up a 10" sub, Zenclosures box, and a new mono amp. I applied eDead V1 to the stock BOSE cover to not let sound resonate in the stock space and come out.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
