rear sub and left side speaker issue
Old Oct 2, 2009 | 11:58 AM
lafingas's Avatar
lafingas
Default rear sub and left side speaker issue
while driving, braking, and acellerating my driver side speakers and rear sub goes out and in...it sounds like a wire is shore but not sure....if it is how would i trace it....
Ive already taken it apart at the head unit and speaker to make sure the connections are good....and they are....dont know what else to do....
by the way i have the factory bose system...lemme know if you guys run into this issue ....
Old Oct 2, 2009 | 12:05 PM
jubes's Avatar
jubes
I have the same issue... the rear sub is because of the sub amp that powers it, apparently a relay switch within the amp is the cause. There's actually a thread about it and how you can temporarily fix it. I've done the fix and it was only temporary.
As for the left speaker, I have had the left speaker changed, as well as the tweeter.... essentially from all the reading I've done on it, its the amplifier. So if you're warranty is still effective, I would take it to a dealership and have them replace that, and urge them not to change the speaker itself but only the amp.
hope this helps.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
